Best floorstanding plan for Alpair 10.2 ? - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 19th September 2012, 01:43 AM   #31
frugal-phile(tm)
planet10's Avatar
I'm just thinking in terms of the simulated response... most would go for a sealed box with Q = 0.707 = butterworth = max flat or 9.2 litres. There is nothing to stop you from extending the sides down and filling the void with sand -- making it more difficult to knock over.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th September 2012, 10:40 AM   #32
Scottmoose's Avatar
Originally Posted by planet10 View Post
29 litre is probably a bit large after you damp the box. I'd suggest damped and 20-23 litre.
I was thinking a high output impedance amplifier might be in the mix somewhere, in which case the extra would be useful. Agreed though, with a high DF, smaller would be better once suitably stuffed.
Old 19th September 2012, 03:18 PM   #33
You can always put a false bottom in the cab and ballast below.
Originally Posted by dekiller View Post
But, 29L already seems small for floorstanding. Am I do the wrong math?
I was so much older then, I'm younger than that now.
Old 19th September 2012, 06:48 PM   #34
dekiller's Avatar
Just curious, does anybody has experience with it on backfiring BLH?
Old 19th September 2012, 06:51 PM   #35
Scottmoose's Avatar
If you're partnering with subs, a back horn isn't likely to be necessary, unless you happen to like the power-response produced by the larger radiating area within it's operating BW.
Old 19th September 2012, 07:42 PM   #36
dekiller's Avatar
Just want to know their effect. If they really shines, why not. Subs is always a backup.
Old 21st September 2012, 06:38 PM   #37
dekiller's Avatar
Stick to the Pencil 10.2 after considering different setups, since I have no idea how MA drivers sounded. Pencil 10.2 should be a good reference. Thanks to all the nice guy here.
Old 22nd September 2012, 03:03 AM   #38
Default Jim Griffin A10.2
Hello! What about these:Jim Griffin A10.2 MLTL with variation
Mark Audio Alpair 10 MLTL Design
How do they compare with the Pensil 10.2 and Bob's M10-A10?
Thanks,
Adel
Old 25th September 2012, 05:47 PM   #39
dekiller's Avatar
As they said, M10-A10 has little edge, but not big difference.
Old 25th September 2012, 06:15 PM   #40
chrisb is offline chrisb  Canada
which "who" exactly?
simulations are one thing, but has anyone actually listened to all the cited designs in the same room / system to formulate a real-world impression of their relative strengths ?
Having heard 2 different Pensils ( 7 and 12.P), and the 10.2 in several designs, of all these named, I'd be inclined towards Bob's, even if only for aesthetic reasons. But to extract even more from this driver, I'd probably wanna try the Woden Silbury. .
now on sabbatical
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 08:21 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 7 - 10 Litre BR Tower plan markaudio Markaudio 14 8th November 2010 06:45 AM
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 12:48 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
