Alpair 12P cabinet options - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 3rd October 2012, 09:25 AM   #11
It was in the "old" Super Pensil box, in fact they took the A12s out so I could listen to the A12Ps. Probably this box was not optimal for the A12P yet it was already very, very good.
Much, much better than most of the Fostex speakers in my opinion.
And I heard more details than with my quite ok Beyma coaxial-based speakers.
I wonder if the small bookshelf designs that I saw in other threads would need a baffle step filter. The sound in the wider Super Pensil was very good and balanced without extra filters.
As an aside, they had Lowther TP1s playing as well, and they were very nice too, without the "shout" that I feared. But inpractical speakers !
Old 3rd October 2012, 09:20 PM   #12
Scottmoose's Avatar
Not really -not, at least, the one I did, unless they're well out into the room, in which case you presumably wouldn't want a standmount in the first place. They're not going to shift air like an Altec 604, but within the constraints of a smallish standmount & a 6 1/2in wideband driver, they do a solid job in the kind of small - medium spaces they were intended for.
Old 9th March 2013, 09:53 AM   #13
Send a message via AIM to Doctorcilantro Send a message via MSN to Doctorcilantro Send a message via Yahoo to Doctorcilantro
Hi all,
I have some bass reflex (rear ported) here that have damaged drivers and wondering how the Alpair 12P would fare in them.
I don't have details on internals but they are:
Dimensions: 23"H x 11.5"W x 11"D
Port you can easily fit adult fist through. 30 pounds each.
Old 9th March 2013, 03:53 PM   #14
I was going to post something like "Wouldn't that be like retrofitting a V-12 Ferrari engine into a trash collection truck?" but I won't.
Old 9th March 2013, 04:20 PM   #15
Silverhair + tricorder + inane post. Yup. Time to turn in the towel.
I wouldn't call a 92db/w driver a Ferrari either...
Old 9th March 2013, 06:21 PM   #16
frugal-phile(tm)
planet10's Avatar
Assumming 3/4" material, twice the volume i'd be comfortable using for A12.2p
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th March 2013, 06:21 PM   #17
vinylkid58's Avatar
Ok, volume in the low 30's, a little big for the A12p in a BR, but not the end of the world bad.
So roughly a 4" dia. port? Somewhere around 8-8.5" long would do it. If it's a lot shorter, you may want to retrofit a smaller dia. longer port into the box. Would work as a "break-in" box while you build something better.
jeff
Alpair 12P Gen. 2 (paper cone) markaudio Markaudio 247 3rd June 2013 03:51 PM
Just ordered a set of Alpair 12P (Madisound USA) StevenZ Markaudio 158 9th November 2012 05:32 AM
StevenZ's Alpair 12P Build StevenZ Markaudio 129 9th October 2012 02:56 PM
Link to Alpair 12p plan broken? bqc Markaudio 2 7th September 2012 06:18 PM
Alpair 12P arrival! Monte Verdi Full Range 4 24th June 2012 09:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
