CHP-70P (Gen2) Mounting questions - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 7th September 2012, 12:56 PM   #1
RickH is offline RickH  United States
Default CHP-70P (Gen2) Mounting questions
I am ready to order a pair and would like to know the screw diameter for mounting and the proper size quick connects for wiring. This will be my first build so I will likely try different cabinets and would rather use quick connects than solder, unless quick connects are not recommended. Thanks in advance!
Rick
Old 7th September 2012, 05:54 PM   #2
chrisb is offline chrisb  Canada
Rick
Unless you're not comfortable with soldering, I'd highly recommend it over quick connects - considering the time required to carefully re & re the 4 mounting screws, how much time do you need to save?
As to the screw size, IINM the very nice mounting screws shipped with the drivers are a coarse thread M4 (you'll need a hex key) with non tapered shaft - I'd use a slightly larger pilot hole than for a tapered shaft (usually 5/32 or 9/64 in my case), and maybe even a little wax on the screw threads. Mark has engineered damping into the materials and design of the flanges and gaskets - these don't need to be "Linn tight" .
now on sabbatical
Old 7th September 2012, 06:28 PM   #3
frugal-phile(tm)
planet10's Avatar
I do not recommended quick connects.
Dimensions for the driver can be found here http://frugal-phile.com/boxes-markaudio.html
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Speaker Cabinet & Baffle Mounting Questions joelostrom Construction Tips 2 7th August 2012 09:16 AM
Mark Audio CHP 70 Gen2 loninappleton Full Range 16 4th May 2012 08:42 AM
Fe127/Fonken driver mounting questions strider75 Full Range 8 14th August 2008 06:56 PM
1kW Gen2 ChocoHolic Class D 90 10th August 2008 03:45 PM
2 Unrelated questions -buffers and transformer mounting Adam M. Chip Amps 27 11th August 2004 08:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
