Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 19th July 2012, 08:17 AM   #1
gooki is offline gooki  New Zealand
Default A couple of Alpair 6 builds.
I have finally made some time to get these builds underway.
One set of floorstanders and a pair of bookshelves. I have both the 6M and 6P so will see which I like best.
The cabinets are made from solid timber (Matai), with allowance for expansion/contraction.
Old 19th July 2012, 08:33 AM   #2
neoinc is offline neoinc  Singapore
neoinc's Avatar
I think they are very well made.
Old 19th July 2012, 08:38 AM   #3
Hi gooki. Can you expand more on the "with allowance for expansion / contraction"? I'm not sure how to accomplish that exactly for solid wood speaker enclosures, but I'm itching to try for my next bookshelf build.
Old 19th July 2012, 09:12 AM   #4
Wood expands across the grain.
For the sides and top run the grain up and down, and left to right, never front to
back. You can glue these joins. This way the enclosure will only expand along the z axis.
The front baffle sits on the above 4 sided box with foam gasket all the way around. It is held in place with screws from the inside. No glue.
The rear panel is inset into the 4 sided box using a rebated channel, Approx 2mm clearance, again with a foam gasket and no glue. If you use plywood or mdf for the rear you can simply glue it in place, no need for a gasket or clearance.
Old 19th July 2012, 09:51 PM   #5
Images attached.
Old 1st August 2012, 09:36 PM   #6
Some more progress, see pics below.
Should be finished next week.
Old 14th August 2012, 11:53 PM   #7
Bookshelf speakers all done, pics below.
Old 15th August 2012, 12:38 AM   #8
vinylkid58's Avatar
Lovely looking wood. Nice work on the enclosures.
jeff
Old 15th August 2012, 01:56 AM   #9
Thanks. I love it how the grain wraps around the driver on one of them.
Old 12th October 2012, 10:13 AM   #10
mondogenerator's Avatar
lovely gloss finish. Did you fill the grain? What laquer? 2pack or boggo poly?
It still amazes me every time I get something right
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 03:37 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 03:19 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 05:04 AM
cap couple or direct couple class A SE amp? AudioGeek Solid State 7 7th May 2005 06:16 PM
Copyright ©1999-2013 diyAudio
