Minor error on the A10.2 Spec sheet - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 18th July 2012, 03:11 AM   #1
Bob Brines's Avatar
Default Minor error on the A10.2 Spec sheet
Mark,
I was machining some baffles for the A10.2 today and I noticed that the flange thickness with the bessel on is incorrect. It shows 5/32"-11.8mm. it should be 15/32"-11.8mm.
I always measure from the driver in hand, so no problem. Actually, I like the driver to be slightly proud of the baffle, so I did the rabbet 7/16".
Bob
2SJ81/2/3 and 2SK225/6/7 spec sheet? AMV8 Parts 0 21st June 2012 08:17 PM
Looking for spec sheet - Vifa M18WO-09-06 wrankin Multi-Way 3 13th January 2011 10:07 PM
spec sheet for tc9152 analog switch ostie01 Parts 2 19th March 2006 11:34 PM
2N2592 spec. sheet - Where to find ? Jan Dupont Parts 6 19th May 2005 05:06 PM
Help! Dumb questions about a spec sheet.... Morse Tubes / Valves 15 2nd June 2004 07:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
