StevenZ's Alpair 12P Build - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 2nd July 2012, 03:12 PM   #11
StevenZ is offline StevenZ  United States
Jimbro, where abouts in Texas are you located? San Antonio here.
Old 2nd July 2012, 04:41 PM   #12
zman01 is offline zman01  Bangladesh
Originally Posted by StevenZ View Post
apparently the CNC router isn't cutting all too accurately at the moment. All of my parts were almost 1/16" short which compounded into big problems.
Looks like I'll have to do it the good ol' fashioned way on this one. Time to dust off the hand routers and panel saw.
Steven
And I thought you were going to share listening experiences today...
Old 2nd July 2012, 05:03 PM   #13
von Ah is online now von Ah  United States
von Ah's Avatar
There must be a way to salvage that wood for another enclosure/driver...
Thanks for the cool video!
Old 2nd July 2012, 06:14 PM   #14
vinylkid58's Avatar
Some of it could probably be used for a MarKen12.2p build.
jeff
Old 2nd July 2012, 07:23 PM   #15
jimbro is offline jimbro  United States
Hi Steven - I'm out in the sticks off highway 6 about 50 mi. NW of Houston. Maybe we'll meet at the Lone Star fest next year. I'm determined to make it.
Old 3rd July 2012, 04:18 AM   #16
chrisb is offline chrisb  Canada
yup - it only takes a teeny error in one line of possibly hundreds of lines of program code to mess y'all up pretty good
and of course all the run time simulations in the world won't tell whether the pieces that come of the CNC will actually fit together
then of course there's the "oops, the material's not actually the thickness we thought, or it varies from one sheet to the next in a lift of 40, or even within the same sheet - and only a fraction of a mm is enough "
now on sabbatical
Old 3rd July 2012, 05:09 AM   #17
So all in all, there's nothing more reliable than the tried and tested methods of the non-CNC crowd?
Just thinking aloud - since StevenZ has already cut the parts and 1/16" is around 1.6mm, maybe it's worth a shot to glue up the pieces instead of trashing them? Not a perfect Super Pensil, but will be very close? If it's great sounding, then you can always make another one.
Old 3rd July 2012, 08:25 AM   #18
frugal-phile(tm)
planet10's Avatar
if its only a 16th out that is close enuff to perfect, now if it was 2" short... i'd not worry about it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd July 2012, 01:32 PM   #19
Bob Brines's Avatar
It all depends on where that 1/16" is. Personally, I can do better than 1/32" on long cuts on my table saw, but I can't do reliable crosscuts on the end of long boards. And I don't care. I make sure the sides/back/front are a little long and use a trim bit in a router to square things up.
When I cut into a 4x8 panel, I set up the layout so that the end cuts all line up. I then have all of the panels at least the same length. I can get the crosscut dead square, but the length floating by the width of the pencil mark and how even the end I measure from is. I then do the cut with a circular saw with a nice Freud blade in it.
Bob
Old 3rd July 2012, 06:07 PM   #20
AlanL is offline AlanL  United States
Please check this video 5 Cuts to a "Perfect" Cross-Cut Sled - YouTube
I use the sled for everything that will fit in it.
Alpair 6M build TISONN Markaudio 15 28th August 2013 05:32 AM
Alpair 12P Gen. 2 (paper cone) markaudio Markaudio 247 3rd June 2013 03:51 PM
Just ordered a set of Alpair 12P (Madisound USA) StevenZ Markaudio 158 9th November 2012 05:32 AM
Alpair 12P arrival! Monte Verdi Full Range 4 24th June 2012 09:17 PM
Mark Audio Alpair For First Build? d3ll Full Range 10 17th December 2009 08:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
