#11 | |
Overkill, in DIY audio? - c'est ne pas possible ![]() but rather than attempt for maximum theoretical LF output with this driver, I'd be inclined towards something that sacrifices extension for linearity / "finesse" - easy for me to say, cause the boxes are 2/3 built awaiting drivers to confirm dry fitment of bracing parts
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#12 |
...so when do we get to see the plans for those 2/3 built boxes?
And btw, just how much extension are you losing over the pencil's? I like the idea od linearity, when they're up and running, 'd like to see a transfer function Fq/Ω. |
#13 |
frugal-phile(tm)
They will be part of the Alpair 12 miniOnken paid planset.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#14 | |
Thanks Chris! Prefer the finesse over big low end. It will undoubtedly be very interesting how box and speakers do upper register and (mid) lows . I plan on OB experiments as well good luck! Ramon |
#15 |
Will be watching for the release of this set Dave. Can't wait to start building.
Gary One good driver is all I need. |
#16 |
They have landed in St Paul.
Beautiful drivers Mark!
#17 |
Am I perhaps looking in the wrong place or are the Super Pensils enclosure plans not yet up?
#18 |
#19 |
Thanks Jeff!
#20 |
Please remember that if you plan on rebating the 12Ps for flush mounting that allowing for gasket compression and possible veneer finish, the required depth for flange and super-gasket is 10mm - so a single layer of 18mm won't leave a lot of meat for fasteners, particularly after the rear of opening is relieved with chamfer or round-over.
On the MK12Ps currently on the bench I used 18mm + 6mm ply for the baffle, which leaves approx 14mm of core for the hex head mounting screws.
| Thread Tools | Search this Thread |
| Alpair 12P Gen. 2 (paper cone) | markaudio | Markaudio | 247 | 3rd June 2013 02:51 PM |
| Alpair 6p vs alpair 6m vs alpair 7 | timreeves | Markaudio | 11 | 8th January 2013 03:37 PM |
| Drivers to Madisound USA - Progress | markaudio | Markaudio | 24 | 25th November 2011 01:34 AM |
| Behringer DCX2496 and XLR->RCA cable set (CA, USA) | CharlieLaub | Swap Meet | 2 | 31st August 2011 02:59 AM |
| Component set found on Madisound | ma_tt316 | Car Audio | 4 | 22nd March 2011 12:06 AM |
