Just ordered a set of Alpair 12P (Madisound USA) - Page 15 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 6th July 2012, 06:04 AM   #141
frugal-phile(tm)
planet10's Avatar
Chris built boxes to complement them.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th July 2012, 02:17 PM   #142
StevenZ is offline StevenZ  United States
I actually think in those walnut cabs some chocolate colored drivers with gold "tracks" on them would be stunning. Do you by chance know how much mass you're adding to the driver when you're coloring them? It seems like the more porous paper cones would suck up a bit more material than the metal cones. I'd be interested to read your findings on how the enable process varies between the metal and paper coned Markaudio drivers.
-Steven
P.S. Those red enclosures with red drivers looks great!
Old 6th July 2012, 04:30 PM   #143
chrisb is offline chrisb  Canada
-Steven
Reds are A6Ps - same paper as 12s, - which does take some colors quite nicely - the veneer was remnants from a lovely sheet of highly figured Cherry. With an alcohol based penetrating stain and a couple of coats of NC - the camera can't quite do justice to the depth and life of the grain
As to stock color of the pastel blue paper not quite working with walnut - there's always the option of fabric grilles
now on sabbatical
Old 6th November 2012, 08:49 PM   #144
mor2bz is offline mor2bz  United States
with 22 liter Vas for the Alpair 12 and 43 Liter Vas for the 12p, I don't understand
how the same boxes can be used for both.
Old 6th November 2012, 11:47 PM   #145
frugal-phile(tm)
planet10's Avatar
They can't really. Qts and Fs also play a role.
dave
Old 7th November 2012, 12:52 AM   #146
so which box to use for 12p?
Old 7th November 2012, 05:44 AM   #147
zman01 is offline zman01  Bangladesh
mor2bz,
The new Pensil plans:
http://frugal-phile.com/boxlib/pensi...lan-180412.pdf
Compact BR box:
http://www.madisound.com/pdf/SmallRe...22p-191012.pdf
For Mar-Ken12P you need to e-mail Planet10.
For Avebury BLH rear double mouth horn plans you need to e-mail Scott Lindgren at Woden Design.
Old 7th November 2012, 05:54 AM   #148
frugal-phile(tm)
planet10's Avatar
I will be doing a CGR that will be released for free use.
dave
Old 7th November 2012, 12:35 PM   #149
Originally Posted by planet10 View Post
I will be doing a CGR tha will be released for free use.
dave
Thanks Dave, kind of you to make the CGR plans availble.
BTW, have you applied your mods on any of the A12P yet?
Old 7th November 2012, 08:55 PM   #150
I will be doing a CDR tha will be released for gree use.
dave
y'all really got start reviewing your tipyng b4 pucnhing the bo gutton
gree= environmentally friendly - please recycle as much material as you can
now on sabbatical
Alpair 12P Gen. 2 (paper cone) markaudio Markaudio 247 3rd June 2013 03:51 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 04:37 PM
Drivers to Madisound USA - Progress markaudio Markaudio 24 25th November 2011 02:34 AM
Behringer DCX2496 and XLR->RCA cable set (CA, USA) CharlieLaub Swap Meet 2 31st August 2011 03:59 AM
Component set found on Madisound ma_tt316 Car Audio 4 22nd March 2011 01:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
