Just ordered a set of Alpair 12P (Madisound USA) - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 27th June 2012, 03:14 PM   #101
doorman is offline doorman  Canada
doorman's Avatar
i let others debate the sonics vis a vis BB/MDF et al. For me, however, the MDF dust is a deal-breaker.
Best of luck with your project.
I hope to hear a pair of Alpair 12's at Dave's later this summer---
don
Old 27th June 2012, 03:38 PM   #102
StevenZ is offline StevenZ  United States
Thanks Doorman, I think I'll just go with it since I have plenty of MDF in stock. The dust isn't a big problem for me as I make sure to wear proper eye and respiratory protection when cutting/routing. Has anyone else gotten any time with the 12P's yet? I'm curious to read any initial impressions, even if only during break-in.
-Steven
Old 27th June 2012, 03:50 PM   #103
mp9 is offline mp9  United States
I wouldn't use MDF, here's a possible alternative:
Originally Posted by chrisb View Post
absobloodylutely - but certainly not as cheap as hardwood plywood - speaking of which you might want to look into the Murphy Hardwoods Maple Multi-ply, over the past 6 months or so I've noticed a huge drop in quality of Russian sourced Baltic Birch, and have started using the Murphy - costs more, but is a gorgeous product (for now, anyway)
Alpair 12P Gen. 2 (paper cone)
Old 27th June 2012, 04:03 PM   #104
I've used Murphy before, it's decent stuff. Something I haven't seen before in Murphy's plywood is pieces of string. I can't quite figure out why there would be long pieces of white string on every sheet.
Old 27th June 2012, 04:17 PM   #105
chrisb is offline chrisb  Canada
I certainly haven't run into any issues with contamination or delamination of either the higher priced Multi-ply or more generic "shop" VC ply from Murphy, cut can certainly relate tales of metal parts (machine nuts and shavings) in cheaper MDF.
Frankly, considering the cost of the drivers in question, I'd spring for the higher quality plywood - but then my mind was made up on this subject years ago.
now on sabbatical
Old 27th June 2012, 06:21 PM   #106
frugal-phile(tm)
planet10's Avatar
don
Chris is finishing the Mar-Ken12.2pT to match these WoofTs. The drivers come off the break-in bench tommorrow night so we should have them working Sat (Chris will likely get 1st crack at them).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th June 2012, 06:41 PM   #107
dave
unless I'm too busy working in the garden or sumpin
now on sabbatical
Old 27th June 2012, 08:02 PM   #108
vinylkid58's Avatar
Saturday's forecast is for light rain.
jeff
Old 27th June 2012, 08:54 PM   #109
doorman's Avatar
jeff
I'd bet Mrs. B has heard it before!
don
Old 29th June 2012, 11:59 AM   #110
markaudio's Avatar
Default NEW 12P BATCH FOR MADISOUND
Hi Guys,
Brian from Madisound has let me know all the 12P first stock has gone, so he's asked me to start making another 80 drivers. We'll start making them later next week.
Cheers
Mark.
Alpair 12P Gen. 2 (paper cone) markaudio Markaudio 247 3rd June 2013 03:51 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 04:37 PM
Drivers to Madisound USA - Progress markaudio Markaudio 24 25th November 2011 02:34 AM
Behringer DCX2496 and XLR->RCA cable set (CA, USA) CharlieLaub Swap Meet 2 31st August 2011 03:59 AM
Component set found on Madisound ma_tt316 Car Audio 4 22nd March 2011 01:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
