Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 3rd May 2012, 03:31 AM   #1
Default Alpair 1.5-way Speaker?
I am relatively new to speaker building. I built the microtower bipoles with Alpair 7's as my first project and I love them. I use them for music. With the Alpair 12 out of stock when I wanted to do some home theater speakers, I then built three pensil 10's for my home theater.
I feel like the Alpair 10's have been nice for dialog clarity but maybe lack a little oomph in the low end, particularly since the room they are in is pretty large. I fear that at loud volumes I am pushing the x-max and maybe getting some distortion. My solution for now is to raise the crossover to the subwoofers.
I was wondering about the possibility of building a transmission line type design but with 2 matching drivers, say Alpair 10's. They would cross over relatively low such that only one would be firing for treble and midrange, eliminating any cancellation effects at higher frequencies. Down low they would share the load, effectively doubling the driver area and as a bonus providing baffle step compensation.
I know this would be less efficient and the crossover in some sense defeats part of the purpose of full-range drivers, but I feel this is minimal since it is crossing over between identical drivers. Also, my home theater amp is sufficiently massive as to make the question of efficiency largely irrelevant, I think.
Any comments? I have tried to find a thread like this and failed. Is this a reasonable idea or is there something I am missing.
Old 3rd May 2012, 03:36 AM   #2
LOL, the moment I post this I see the dual driver thread about 5 down. So dual drivers seem to be doable. I guess I still would ask about a full dual driver vs. 1.5-way. My sense is that the dual driver 1-way speaker further down in this forum is more for nearfield, and that I would have problems with it in a home theater, but again I may be misunderstanding the interference issue between identical drivers.
Old 3rd May 2012, 03:42 AM   #3
frugal-phile(tm)
planet10's Avatar
The concept is fine. Do note that the A10.2 goes lower than the A12. And that 2 A10s aren't much more $$$ than 1 x A12 (if you could get them)
There are a number of Twins in my mini Onken plansets.
Here is one Toppsy did with A10.1
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd May 2012, 03:47 AM   #4
Beautiful. I feel another project coming on. This speaker building thing is relatively new to me but strangely addictive.
Are these straight one-way designs? If so, aren't there some sort of interference pattern problems for wavelengths shorter than the driver separation?
Old 3rd May 2012, 04:24 AM   #5
frugal-phile(tm)
planet10's Avatar
Toppsy ran it as a straight 1-way... he didn't comment on any audible issues with combing.
But there are a number of ways to filter them for different results with different amps.
dave
Old 3rd May 2012, 04:27 AM   #6
doorman is offline doorman  Canada
doorman's Avatar
Lovely build,as usual, Colin: Care to share your listening impressions vis a vis
the Mar-Ken cabs w/ single 10.2's?
Best
Don
Old 3rd May 2012, 05:05 AM   #7
Thanks. I found Toppsy's original article on his build. It is here: audio-talk :: View topic - My Latest and Last Speaker Build
He later did a MTM design using fostex drivers here: audio-talk :: View topic - Fonken FE167eN + FT17H MTM Floorstanders
I may have to try this
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 03:37 PM
Centre Speaker using Alpair 10 and some limitations zanlation Markaudio 20 24th February 2012 10:25 AM
Cello speaker with Mark Audio Alpair 12 driver speakermaker Full Range 16 14th August 2011 08:07 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 05:04 AM
Alpair 10 Centre Speaker geepee Full Range 13 29th May 2010 01:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
