| Markaudio Designers and builders of audiophile grade drivers |
#11 |
Speakerholic
A screw-gun clutch is helpful also.
#12 |
also keep in mind that the hex head mounting screws Mark supplies are more like a sheet metal thread - constant diameter shaft and higher thread pitch than a lot of wood screws, so a slightly larger pilot hole will prevent the screw from getting too tight before fully set, and therefore harder to judge when "just right"
and a little soap or paraffin wax on the threads is helpful - lube can be your friend
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| CSS EL70 | epilou | Full Range | 51 | 20th March 2012 02:28 AM |
| EL70 Break-in | cogitech | Full Range | 8 | 1st October 2011 05:32 PM |
| EnABL EL70 | ndwalker1 | Planet 10 hifi | 2 | 24th May 2011 06:05 PM |
| El70 in Pensil? | type | Full Range | 12 | 11th September 2010 07:41 PM |
| Floorstander with EL70 | AlejandroR | Full Range | 16 | 20th December 2009 04:22 PM |
| Page generated in 0.06459 seconds (68.44% PHP - 31.56% MySQL) with 11 queries |
