What Amp do you use with your Mark Audio Drivers? - Page 16 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 25th February 2014, 05:34 AM   #151
fitmartin's Avatar
found a calculator on the web
measured more accurately
cabs are 19.4 liters
Old 25th February 2014, 01:06 PM   #152
nirvana is offline nirvana  Canada
nirvana's Avatar
27 x 36 x 22 cm : 21,383 liters
finally 51 liters of pensil 10p would be too big for nothing ?
Old 25th February 2014, 01:10 PM   #153
nirvana's Avatar
what do you think of that 17 liters simple reflex ov9 ?
Old 25th February 2014, 05:05 PM   #154
chrisb is online now chrisb  Canada
simply put, I think there are completely different operating principles for an MLTL, or tapped hypex horn such as the FHs ( 3 or XL) - the latter for which I've not bothered to calculate the volume ahead of the choke and horn mouth.
haven't heard the simple reflex - should maybe blast together a pair of those - a guy can't have too many unused speakers, or amps, or DACs, or ......
now on sabbatical
Old 25th February 2014, 05:28 PM   #155
frugal-phile(tm)
planet10's Avatar
About 21 litres once you account for the volume of the back of the driver, but ignoring the braces (there should be braces)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th March 2014, 11:54 PM   #156
fitmartin's Avatar
my only comment would be the 19.45 liter rear ported cabs I am using have prompted me to relocate my sub to the theatre room with the SS 5.1 system.
just the right amount of tight bass for my tastes!
Old 2nd May 2014, 08:08 PM   #157
Hi all, I have a set of MLTL Bipolar 4ohm load using the 2 of the Alpair10.2 back to back and needed a tube amp for around $1200. I'm concerting the following as a kit. Any recommendations highly appreciated
ELEKIT TU-879S>* (using KT-88)
ELEKIT speaker (with 2A3 or 300B)
Thanks,
Old 2nd May 2014, 09:18 PM   #158
I've owned SET amps in 3 of the types supported for the 2 amps listed (the 879 will accommodate EL34 as well) and am a sucker for the 2A3. If the 8233 can auto-detect for the 300B, I'd be inclined to go that route - i.e. you can swap out when you want a change in tonality & power. The nominal watt or two per channel difference between the KT88 in this application and 300B is not really all that significant - it's the first watt that counts
now on sabbatical
Old 3rd May 2014, 01:27 AM   #159
I use a Tubelab SSE. I have it set up so I can use EL34, KT88 and KT90 tubes.
My 12P's are still playing in the cardboard box...Some day soon, I'll have to build a real box for them.
Old 3rd May 2014, 07:13 AM   #160
two words for this driver:
SuperPensil
SuperPensil
now on sabbatical
Pensil Series for Mark Audio Drivers planet10 Markaudio 46 28th September 2011 08:19 PM
Mark audio I am looking at two of your drivers help please. phil09 Markaudio 14 11th June 2011 03:09 AM
Mark audio drivers in ipod dock joe58 The Lounge 5 16th March 2011 02:55 PM
X_lin for Mark Audio drivers? rpnfan Markaudio 3 26th October 2010 09:57 PM
Mark Audio Drivers are on Sale!! mdikovics Full Range 24 7th July 2009 07:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
