#41 |
I figure it leaves the option for "audiophile glue"
Somebody would complain that the stock glue makes the driver sound too boomy, others would complain it veils the midrange. I used the new Mundorf audiophile glue on the MA driver and it produced treble better than my RAAL ribbon tweeter! Just the driver, thank you very much! |
#42 | |
Polymer baskets (frames) aren't the cheap option. Pressed steel and low-mid grade cast are for commercial reasons are cheaper to make, therefore the choice of most makers. Polymer frames designed and made right (note the word "right") will out perform most any other frame type. But the bigger the frame, the greater the cost. There's likely no such thing as a cheap big polymer frame (that's reliable) and likely will never be. Makers have to live in the real world (even me) so I'm not planning to make anything bigger than the Alp12 frame using polymer at this stage. I know a few dealers who'd love to see glued covers. I came under allot of pressure to fix all covers at the factory. As said previously, its a question of "freedom of choice". Where possible, I try to make the driver practical for as many users as possible. So the final decision to deploy covers, extension connectors and the rear magnet cover in the case of the Alp7 is down to you guys. Most of you know my recommendations. Cheers Mark. Last edited by markaudio; 8th January 2012 at 05:25 PM. |
#43 | |
so let's read between the lines ? ........
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| Thread Tools | Search this Thread |
| an 12' cast frame in Metrnome or 5.6mk2 | HPH | Full Range | 8 | 18th November 2011 04:20 PM |
| Eminence 12" cast frame coaxials | exurbia | Swap Meet | 0 | 20th February 2011 01:00 AM |
| Cabinet for AN 12'' cast frame? | HPH | Full Range | 5 | 20th September 2010 11:13 PM |
| Cast Frame Magnavox 15"? | Cloth Ears | Multi-Way | 6 | 27th September 2007 03:36 AM |
| any cast-frame super 8 users? | freddi | Full Range | 12 | 12th September 2007 08:19 PM |
| Page generated in 0.08541 seconds (74.26% PHP - 25.74% MySQL) with 10 queries |
