#21 | |
While a 5.1/etc HT system is not exactly a FAST configuration, it does allow experimentation with different driver / enclosure types at each location. My early trials of dialing in current rig took the opposite approach (i.e. multiple small sealed SDX7 woofers and vented mains and center) . Perhaps the lower XO points employed ( circa 100 or so) are at play, but I found the combination of sealed and ported simply didn't integrate as well as did later all vented enclosures - Alpair7s in the front row, and dual 8" OEM (Eastech) corner located woofers. My only exposure to integrated FAST systems were the little 2-way Tysen with sealed SDX7 and small highly damped TL with Fostex FF85K, biamped at approx 330Hz - the XO transition was fairly innocuous; and a Lowther/Tone Tubby(?) OB at an audio show. The latter system not only kicked a$$, but would also tear your line of credit a new one.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#22 | |
frugal-phile(tm)
20-40 40-80 80-160 160-320 320-640 640-1.28 kHz (some rounding usually happens here to make things fit) 1.25-2.5 k 2.5-5k 5-10k 10-20k My goal with helper woofers is to try to get to 25-30 Hz F3 which is close to Bills 20 Hz F10. To really get the ommff to do those organs and really dynamic drums, one needs to look at a set of subwoofers <50 hz placed in the room to counter the major resonces (i am sitting on 4 SDX10 to slot in below the 8 SDX7 dave dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#23 |
#24 | |
Mind you, I still have little practical experience in the field of speaker building, so I really appreciate all kinds of inputs here |
#25 |
Ah, an excellent point. One I've used myself, but obviously overlooked it in this discussion. Thank you.
#26 | |
Your goal is very much aligned with mine. I prefer sealed box designs that provide a more gradual rolloff but accomplish the same result. It also makes the cabinets a bit more simple to design and implement. When someone has my level of cabinet building skills, a sealed box is about the limit. Below 120hz there's 60, 30, 15, 7.5, 3.75, 1.875, .99, .495.... etc. out to an infinitesimally small number. This results in the same number of octaves below 120 as above. Infinity. I would expect 4 x SDX10 would provide reasonablly deep performance in the right enclosure. The swept area is a little bigger than what I'm currently using for deep bass. I'm still using a pair of Nick's old Lambda SB12s each in around 4 a cu ft sealed box. Properly placed at the midpoint of the long wall, they go too deep for me to measure (I can only measure to 20hz) and pretty much take care of any deep stuff I can throw at them. But they are positively awful at higher frequencies. Low order crossovers are totally out of the question, fourth order active crossover and bi-amping is needed at a minimum. Below a certain point, room and speaker placement come heavily into play in terms of how to get deep bass. Though a nice array of large drivers helps, sometimes it only takes a bit of extra room boost to get satisfying results. |
#27 | |
#28 |
How about mixing blh with ported? In whack or out?
#29 |
#30 |
frugal-phile(tm)
I've had good results mixing aperiodic (or near aperiodic as in the miniOnken) with sealed, with aperiodic, and with TLs.
dave
| Thread Tools | Search this Thread |
| Audio Alto with MA drivers? | djanci | Markaudio | 2 | 4th May 2011 03:50 AM |
| MA AUDIO HK-4000D ,NO OUTPUT TO SUBS | WRENCH030380 | Car Audio | 5 | 11th March 2011 10:39 PM |
| Crown MA-12000i / MA-5000i / MA-9000i | jack2040 | Solid State | 4 | 8th March 2011 01:21 PM |
| ma audio hk-4000 ,no sound to subs ?MA AUDIO HK-4000,NO OUTPUT TO SUBS | WRENCH030380 | Class D | 2 | 7th March 2011 11:38 PM |
| FS: horn subs, drivers, 'regular' subwoofer drivers | John Sheerin | Swap Meet | 0 | 1st August 2004 11:33 PM |
| Page generated in 0.12997 seconds (84.18% PHP - 15.82% MySQL) with 11 queries |
