CHR-70.3 - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 13th June 2013, 02:32 PM   #11
Bill poster's Avatar
will the chr70.3 work ok in a waveguide or is the treble abit hot? I've just made a shallow horn/waveguide out of blue model foam (roughly 500hz diameter) as an experiment
Old 13th June 2013, 05:47 PM   #12
Scottmoose's Avatar
Depends on the design of the waveguide.
Old 14th June 2013, 11:02 AM   #13
Thanks Scott, its quite shallow with a rolled edge - I'll take a pic when i have more time (stuck in hospital)
Old 14th June 2013, 11:43 PM   #14
Default CHR-3 in Frugal Horn MK-3
I have the CHR-3 speakers in the Frugal Horn Mk-3, and they are Spectacular! You have to give these speakers time to break in before they sound their best. The sound is well balanced with good bass. Just don't try getting rock concert levels out of them.
I recently had my ultra-picky audiophile friend over, who has an expensive system, and he was impressed.
I running these with a basic Sony HT receiver (hint, hook your CD player or DAC into the RF and LF 5.1 inputs. That bypasses the receiver's crappy input section and gives much better sound). They are playing in a room that is 13' by 25'. The listener is 14 ft. from the speakers.
Old 15th June 2013, 03:14 PM   #15
zman01 is offline zman01  Bangladesh
EdKennedy.
Good looking set of FH Mk-3 you have got in a nice room!
I have CHR-70.2 and these are verstaile drivers. They work well in the FH-Mk3 as do other MA drivers like the Alpair-7, CHP-70 (gen-1), CSS-EL70 (also made my Mark). As you have observed, long break in times are required (good things come to those who wait ) for these drivers, but the results are worth it.
If you don't mind me suggesting - paired to a better amplification and source will likely increase your listening pleasure.
Enjoy your speakers!
Old 15th June 2013, 04:50 PM   #16
Zman,
Thanks for the nice compliment regarding my speakers and room.
I agree, my electronics could use an upgrade. I'm considering building a Tubeland single ended amp sometime soon to check out the world of tube amps.
I built these speakers using the inexpensive CHR-70 to see if I liked MarkAudio's full range speakers. I am still amazed at the quality of the sound from a little 4" driver as long as I keep the volume reasonable.
In the future, I will probably step up to the Alpair 10 or 12 after the electronics gets upgraded.
Old 15th June 2013, 05:48 PM   #17
You mean Tubelab?
The Tubelab Simple SE plays very nicely with my Alpair 12s.
Old 15th June 2013, 06:12 PM   #18
Yup, Tubelab. I need to engage my brain before typing.
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 06:02 PM
New CHR-70 markaudio Markaudio 68 3rd February 2011 02:44 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 02:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 12th January 2010 12:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
