Driver mounting/installation issues - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 21st October 2011, 07:36 PM   #21
StevenZ is offline StevenZ  United States
Zman, I'll definitely report back with further breaking in. I can only assume that they'll just keep getting better and better. I sense that you guys were left wanting more bass due to the small-ish size of the Mar-Ken enclosures. My initial findings in this department were positive, as I believe the Pensil cabinets are a tried and trued design for extracting the utmost potential from Mark's drivers.
I'd say build yourself a pair, if you're not happy with the results, there isn't much loss as far as materials and time goes. They're easy enough to knock out in a couple hours.
Steven
Old 21st October 2011, 09:10 PM   #22
buzzforb's Avatar
You defined the most important parameter already. Your room size. Mine is 16 x 16 and open on one side. Since you clearly have access to the proper equipment, you should build a dMarKen. Tell me what you think. Only took me a day to build and i don't have a dedicated shop. It would work perfectly in your room.
Old 21st October 2011, 09:13 PM   #23
I'll give it some thought. I'm running low on project time due to the upcoming holiday season and other activities I do. So if I build one it may be next year some time. Do you have a link to photos of your dMarKen build?
Old 21st October 2011, 09:17 PM   #24
buzzforb's Avatar
7.3 Variations
It should offer some improvements in some areas as well as some concessions. I would argue that in your room, you stand to gain more than you would lose.
Old 22nd October 2011, 03:23 AM   #25
zman01 is offline zman01  Bangladesh
+1 to what Justin said - my guess is that the Mar-Ken would work very nicely in your 10 x 10 room. Mar-Kens are a more difficult to build than Pensils though.
Old 22nd October 2011, 04:26 PM   #26
markaudio's Avatar
Originally Posted by StevenZ View Post
Mark, I just wanted to take the time to thank you for an amazing product. I've now broken the drivers in for a total of about 50 hours per your instructions. I'm beyond amazed at how great these drivers sound. Simply stunning tonal accuracy, imaging, and everything else. I just can't believe that these sound this great. Thank you!
Just for reference. The 7.3's are being provided power by a Class D Audio SDS-224 amp and an Audio-GD NFB12 Dac/Preamp combo. Simply perfect combination. The speakers will draw you in with their lush detail and make you late for work. I love it! Also, for those who want to know what my newest speaker build with the 7.3's look like, here's a website where you can view my builds. There's also an album on there for my amp build as well as other various builds. Http://Szaiontz.imgur.com
Hi Steven,
Glad you're enjoying the drivers and thanks for the vote of confidence, much welcomed. I'll take a look at the amps your using. I'm interested in taking a look at class D's.
Cheers
Mark.
New? driver mounting method jimbro Construction Tips 5 26th May 2011 03:22 AM
Mounting the driver Ant_222 Subwoofers 1 4th August 2006 02:48 AM
phase issues with mounting 2 ribbon drivers next to each other? thadman Planars & Exotics 9 31st July 2006 06:46 AM
Driver mounting. 2litre Multi-Way 9 21st January 2006 08:04 AM
better driver mounting mike Multi-Way 26 17th December 2004 10:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
