| Markaudio Designers and builders of audiophile grade drivers |
Mark,
The new Alpair 7.3s come with a super gasket that makes the driver instalation easier. With other MA drivers I've used, the gasket was separate from the driver - for isntallation I used to glue the gasket to the baffle hole and screw on the driver. So, if I were to use the same driver in a different enclosure another set of gaskets would be good enough as there was no contact of the adhesive to the driver. Now the super gasket is fixed to the underside of the driver frame. If any adhesive is used, then I fear it will be difficult impossible to remove the driver once installed. Any suggestions on how to proceed? I have a Mar-Ken 7.3 cabinet nearly ready, which should be the home of the A7.3, but would also like to the drivers in a FH Mk3 with removable supra-baffle. -Zia |
#2 |
frugal-phile(tm)
Make sure the rebate is flat and install the driver,
The new gaskets for the CHR/CHP/CHP are sticky one side, and have cutouts so that it can be adhered to the back of the bezel. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Dave,
Rebates are nice and flat on the Ken boxes - will try to make same for the FH Mk3 SBs. -Zia |
| Alpair 6p vs alpair 6m vs alpair 7 | timreeves | Markaudio | 9 | 25th April 2011 09:05 PM |
| Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs | tripathdude | Full Range | 1 | 7th November 2010 05:04 AM |
| Gasket for removable baffle speakers | chatziva | Construction Tips | 2 | 26th January 2010 07:13 PM |
| Curious about Felt as a Speaker Gasket | BlueWizard | Multi-Way | 4 | 3rd August 2008 06:30 AM |
| Has anyone tried sorbothane as a gasket to reduce baffle energy? | mazeroth | Multi-Way | 9 | 26th January 2006 09:18 PM |
| Page generated in 0.06589 seconds (71.50% PHP - 28.50% MySQL) with 10 queries |
