ikea bowl speaker + CHR-70 gen.3 - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 4th October 2011, 12:01 PM   #11
ma10 is offline ma10  United Kingdom
I'm using a tripath pre-amp at the moment, but my colleague thinks I will be much better off with his Yamaha DSP-A2?
Old 4th October 2011, 12:12 PM   #12
lduarte1973's Avatar
If i had those i would either add a sealed sub for full range use or use them as mid/high in a multway speaker system.yes , probably the yamaha will make them sound better.
Old 4th October 2011, 01:03 PM   #13
Yeah, so it would be a good idea if I was adding more speakers in the future I guess...
Old 4th October 2011, 01:31 PM   #14
jacq. is offline jacq.  Canada
Here's something to motivate your inspiration.
http://www.stereophile.com/images/ar...608cabasse.jpg
Old 4th October 2011, 03:31 PM   #15
markaudio's Avatar
Originally Posted by ma10 View Post
Hi Mark,
Thanks for the advice! I think I'll probably end up porting it but I think I will enjoy it as is for a little while before doing so.
On a side note, I was talking to a colleague and he said he's willing to part with a Yamaha DSP-A2 at a very favourable price and I was thinking would this make a better accompaniment to these speakers?
Hi Martin,
Glad to help.
I've had a friend in the UK who used this Yam, very good from what I remember. Some care with the volume control would be needed as its quite powerful for the CHR's.
Cheers
Mark.
Old 5th October 2011, 10:40 AM   #16
Hi Mark,
He says it's in quite good nick so I'll probably take him up on the offer!
Anyway, I did some basic calculations and it seems to indicate that the total internal volume of the speakers, without the internal parts and assuming a perfect sphere, is 9.6l. If I minus all the internal parts (and taking a guess at the drivers too) then it comes out to be around 8.8l... If I were to add a port, would I look for an equivalent normal shaped BR box and what the port size for that would be?
Old 5th October 2011, 12:05 PM   #17
markaudio's Avatar
Hi Mark,
Hi Martin,
If you can get the Yam for a nice price and its in good condition, could be a good buy. Talking of amps, I'm hunting for an all-Japan Luxman 503S this during the coming week in Tokyo - see pic. I've gotta a bit of the "love thing" for vintage Japanese Moffys.
Looking at the bowls, I'd think a 1" (25-mm) diameter port X 50-mm long, Fb around 54Hz, F3 around 49Hz, looks reasonable. This should get you started. I guess you'll try to squeeze them in the lower real bowl? You might want to try 60-mm long to kick off and trim back depending on room placement, your listening preference etc.
Other members might like to try on their software, offer some additional variations on my calcs.
Cheers
Mark.
Old 5th October 2011, 01:45 PM   #18
The finish on that Luxman 503S looks gorgeous!!
Old 6th October 2011, 02:17 AM   #19
markaudio's Avatar
This Lux gained a reputation for smoooooth, possibly due to it's lower power output. I'll use with my home Pensil 7's while I upgrade the 300b's transformers.
Cheers
Mark
Old 6th October 2011, 02:44 AM   #20
jan.didden's Avatar
My take on the IKEA speaker:
The missile nose cone (true!) in the back is the (sub)woofer. Just finished it, haven't had a chance to do more than casual listening though.
jan didden
If you don't change your beliefs, your life will be like this forever. Is that good news? - W S Maugham
Check out Linear Audio!
CHR-70 Gen.3 Line Array markaudio Markaudio 0 8th September 2011 11:16 PM
Classic TQWT for CHR-70 gen. 3 Squeak Full Range 5 3rd September 2011 07:40 PM
Gen 1 CHR-70 source??? dougr Markaudio 2 11th July 2011 09:35 PM
Ikea bowl speaker drivers polop1 Full Range 61 29th January 2011 08:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
