| Markaudio Designers and builders of audiophile grade drivers |
#11 |
See chamfer/angle suggestion pic -
Thx Mark. |
#12 |
glad to see I'm not alone with the burn marks on the scalloped chamfers on plywood - even with an almost brand new bit
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#13 |
OH. I have always champhered all the way around. Not correct?
#14 |
#15 | |
Apologies for any confusion. Where I come from, "chamfer" is often used to describe a smoothed off edge (rounded). For surface mounting (front of baffle) with all the baffle thickness to hand, the angled method might be better. For recessing the driver into the baffle, possibly the rounded might be easiest where remaining baffle thickness is reduced. Go for the method that best suites your level of woodworking skill. The main thing is to try to have the minimum of side wall facing the back of the cone. Cheers Mark. |
#16 |
Mark, is speaker gasket recommended for the A10.2 if surface mounting or does the rubber seal serve the same function?
#17 |
frugal-phile(tm)
In most circumstances the superGasket should be very sufficient.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Alpair 6p vs alpair 6m vs alpair 7 | timreeves | Markaudio | 9 | 25th April 2011 09:05 PM |
| Decorative trim rings | Wardsweb | Multi-Way | 3 | 10th April 2006 12:33 PM |
| Glueing tiles on the back of the cabinet? | blank527 | Multi-Way | 4 | 24th February 2006 04:45 PM |
| Plywood not glueing well | amo | Multi-Way | 7 | 17th July 2004 02:27 AM |
| Glueing MDF enough? | protos | Multi-Way | 17 | 6th December 2003 01:51 AM |
| Page generated in 0.08996 seconds (75.48% PHP - 24.52% MySQL) with 11 queries |
