Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 16th September 2011, 08:55 PM   #1
Default Woden Design (Wessex ML-TL) Aluminum Cabinet ?
Hello, Im new to the speaker design world so please bear with me... I am looking at the Dual Driver, CHR-70, Wessex ML-TL cabinet design with the drivers mounted on the short side as in page two (left side) here: http://homepage.mac.com/tlinespeaker...v92-151209.pdf
I am looking to keep the same design, however, I want the front and back to be 5.5" with a curved 2.25" radius. I will keep the exact same height 43.5" and adjust the depth of the cabinet to match the total volume. Is this a feasable change to the design? Just looking into my options as my material limits the box dimensions slightly. I have both 1/2" and 3/8" stock and want a curved front and back. I have included a top view for a better understanding.
Thanks - I am completely impressed with this forum and the Mark Audio Support...
Old 16th September 2011, 09:10 PM   #2
frugal-phile(tm)
planet10's Avatar
The critical parameters are internal height, cross-section, vent size & distance from the bottom, and (average) driver distance from the top (with 2 facing the same way as close as possible). You can change cross-section shape as long as you don't get a severe aspect ratio or change the area. I did similar when i morped Scott's EL166 ML-TL to make out MTM FAST. When we finish playing with the design we will add some biggish champhers to the sides.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th September 2011, 09:38 PM   #3
Dave, very cool, thanks for the fast response. I am assuming the cross sectional change is not too severe, I am keeping the same internal height, port size and speaker height placement as the original. My other concern was the curved front and back portions and any problems that may arise due to that change.
-Tom
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Can anyone help TL or ML-TL for Alpair 10 _henry_ Full Range 3 31st December 2008 06:31 AM
What's the difference between a TL, a ML-TL and a TQWT? Bricolo Multi-Way 82 28th August 2008 02:17 PM
ML-TL or ML-TQWT with very low Qt driver Henkjan Full Range 6 29th September 2006 02:29 PM
Small box for FE103 - ML TL or ML TQWT? ChuckT Full Range 15 28th July 2004 05:56 AM
Page generated in 0.07197 seconds (70.09% PHP - 29.91% MySQL) with 11 queries
