Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 25th August 2011, 08:24 PM   #1
Send a message via Skype™ to Rullknufs
Default Differences in T/S parameters between CSS EL166 and Woofer No6
Hello!
I've noticed differences in T/S parameters between the CSS EL166 and the Markaudio Woofer No 6.
The first is the Woofer No 6 and specs taken from blueplanetaudio. The second is taken from the CSS EL166 datasheet.
I'm a little confused. Thinking of building an EL166 MTM ML-TL with an EL70 as mid-tweeter.
Anyways, what's the actual differences in sound and function between the black and white ones?
Old 25th August 2011, 10:23 PM   #2
markaudio's Avatar
Hi Rull,
The CSS data was produced in an anechoic chamber. The Blue Planet data is not anechoic. I recommend you follow the anechoic data (CSS).
There are only small differences between the black and white drivers. The white cone is slightly heavier.
Mark.
Old 26th August 2011, 06:40 AM   #3
Okay, thanks
EL166 MTM ML-TL planet10 CSS 89 Today 11:28 AM
DIfferences in ways of measuring Thiel/Small parameters davidallancole Multi-Way 29 19th November 2007 02:49 PM
Parameters for TacT woofer cph2000 Multi-Way 3 24th April 2007 12:08 PM
Chinese made Classic No6.10 - help! mhouston Solid State 21 19th February 2006 06:06 AM
T/S parameters of philips 8'' woofer hydrovac Multi-Way 4 21st August 2005 05:31 PM
Page generated in 0.07572 seconds (66.49% PHP - 33.51% MySQL) with 10 queries
