| Markaudio Designers and builders of audiophile grade drivers |
The driver has a normal flange with bolt holes for mounting, but there is a second loose plastic flange on top of the first. What is that for?
#2 | |
The front cover (flange) adds more mass and rigidity when glued to the frame. For those guys using thinner front baffles (less than 18-mm thick), they may need to fit the driver without this cover (flange) as the recess depth will be limited. Those guys using front baffles thicker front baffles (18 to 25-mm), I recommend fitting the front cover (flange). Most house-hold glues suitable for polymer plastics will do. Apply a thin beed around 25-mm (1") long in-between the frame's screw locations. Some glues can be strong so test its strength by applying a tiny amount to an obscure part of the frame before use. Our graphic designer is making drawings this week so I hope to publish them soon. I'll lock this thread to keep this information easy to access. Cheers Mark. Last edited by markaudio; 23rd August 2011 at 11:48 PM. |
#3 |
frugal-phile(tm)
You will also note that the 2nd magnet can be pulled off. Make sure that this has snapped into place before instaling them.
With the 1st batch of A7.3 driver measues, i had to go back & retest because during handling the 2nd magnet had come off part-way. It was handy to have it removable as when installing in Maeshowe this past WE, it woudln't fit without. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Alpair 6p vs alpair 6m vs alpair 7 | timreeves | Markaudio | 9 | 25th April 2011 09:05 PM |
| Alpair 12 break-in question: 2mm? | Urchinn | Markaudio | 41 | 5th April 2011 05:10 PM |
| Question about Replacing my bookshelves with Alpair 5s | Arunkumar14_th | Full Range | 1 | 26th January 2011 05:29 AM |
| about the shorted ring (flux stabilizer ring) | haggy | Multi-Way | 3 | 4th January 2002 02:04 AM |
| Page generated in 0.06440 seconds (72.06% PHP - 27.94% MySQL) with 10 queries |
