Alpair 10 Gen. MAOP Prototype TW-1 - Page 17 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 7th August 2012, 04:35 AM   #161
chrisb is offline chrisb  Canada
Originally Posted by Scottmoose View Post
Blueprints... now you're talking. Have to deliver them by carrier pigeon of course.
Either way, these are really nice little units. If you want to reproduce Orff's Carmina Burana at ~'live' SPLs and dynamic range (i.e. minimum of 90dB at the listening position & the ability to handle 120dB LF dynamic peaks), then a 5in widebander isn't likely to be the first choice of transducer, but with less extreme demands, they're excellent. It's a nice unit for simply listening to some music. Which is the point, after all.
O, I've been Fortuna te enough to hear a very special recording of this on a system of Gary Pimm's a few years back that is so far a benchmark against which any attempts at reproduction of a "live" performance need be tested
and yes, more than a single pair of 5" cones were involved
maybe when you're finished playing with the A10 MAOPs, we could make some "arrangements" - need a change of scenery, do you now?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 8th August 2012, 09:45 AM   #162
Scottmoose's Avatar
Yeah, I bet.
Probably a permanent one, the rate things are going.
Old 4th November 2013, 06:51 PM   #163
Mark
Do you have T/S parameters of the latest MAOP drivers on what I'm assuming uses the 10.3p as a donor or are they the same as per your earlier post in this thread?
Old 4th November 2013, 07:50 PM   #164
frugal-phile(tm)
planet10's Avatar
At least in the case of the MOAP 7, parameters are close enuff as to be considered the same as the A7.3
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th November 2013, 09:41 PM   #165
Scottmoose's Avatar
AFAIK, all the A10 MAOP units to date have been based on the 10.2 series driver. They come as matched pairs, as I think I mentioned elsewhere, with anechoic sweeps and T/S specs. of the specific drivers, which is close enough to the stock units for a quality enclosure not to be significantly affected. Aside from the cost of the cones & the fact that they are hand-assembled by Mark, Evan or Taniguchi-San (my own are pair 0001A & 0001B built by Taniguchi-san), this is why they cost rather more than the standard units. Chamber time costs, especially for individual drivers.
Community site www.frugal-horn.com Commercial site www.wodendesign.com
Old 4th November 2013, 09:45 PM   #166
Did you have chance to pit these against the standard 10.2 or even 10.3 and 10.1p drivers?
Old 4th November 2013, 10:07 PM   #167
Scottmoose's Avatar
See my remarks above.
Of the stock metal cone Alpair 10s (the 10P being irrelevant in comparative terms given that it is an entirely different unit), my favourite was the first, which was pretty much flat to 20KHz, or as flat as a wideband driver is likely to get. I liked the 10.2, like the 10.3 more, the MAOP model has most of the enhancements of the 2nd generation model with more HF damping. It's an interesting unit for me inasmuch as it appears, within the context of wideband drivers, to have little in the way of obvious character, since the oxidised cone has greater self-damping. Some will like that, others won't. I admire what they do well, since what they do, they do very well indeed, and I wouldn't part with mine.
Old 4th November 2013, 10:16 PM   #168
I wonder if this "lack of character" helps it mate with multiple amplifier designs / types?
Old 5th November 2013, 12:02 AM   #169
frugal-phile(tm)
planet10's Avatar
Originally Posted by smallangryboy View Post
"lack of character"
Might also be expressed as very neutral. We had this same "issue" (ie took some time to realize how good they were) with an A7.3eN/SDX7 FAST we are just completing the finish on now.
dave
Old 5th November 2013, 12:37 AM   #170
I have a pair of MAOP7s as well as a trio of (EnABLed) A7.2s in my home system, and on initial listening found the MAOPs to be "neutral" for sure. Of course as they arrived direct to me from Mark, and even now have less playing time than any of those Dave puts through his break-in procedure before treatment and final pair matching, I shouldn't be surprised that they might sound like they've not fully "opened up" yet.
As Scott notes - the MAOP drivers are special enough that anyone lucky enough to acquire a pair will not likely do anything drastic like get rid of, or modify them.
Alpair 10 Gen. 2 introduction markaudio Markaudio 185 25th May 2013 05:31 AM
Subwoofer for Alpair 10 Gen.2 Alex_77 Markaudio 1 25th March 2011 06:48 PM
Alpair 6 - Gen 2. - Prototype 1 markaudio Markaudio 53 11th November 2010 04:18 AM
alpair 6 + 10 gen 2, availiable Monday norman bates Full Range 2 18th September 2010 09:46 AM
When is the alpair 10 gen 2 coming out ? norman bates Markaudio 10 1st March 2010 10:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
