| Markaudio Designers and builders of audiophile grade drivers |
I am not that experienced with drivers, so I have to admit I am not familiar with "Gm/cm" used by MarkAudio as a unit for the Thiele BL variable. How does this convert to the more common "N/amp"? The conversion must be close to 1:1 as the values seem to be in the same numerical range as driver N/amp values
#2 |
Hmm ... multiply by 10 it seems!
Ratio: (1 newton per ampere / 1 grams per centimeter - Google Search) Conversion: 1 gram per centimeter * (1 newton per ampere / 1 grams per centimeter) in newtons per ampere - Google Search |
#3 |
Thanks - You had a much more clever way of doing the google search. I think 10x is high though. It would yield unreasonable numbers like 38.3 N/amp for the Alpair 7 which seems really high
#4 |
Hi Guys,
Apologies for any confusion. We use G/cm during our testing phases. Its easier for us to calculate loads on the power-train. For published results, we switch to T.m. I forgot to set this facility on LMS. We'll go back and re-calculate using LMS. Give me a few days to sort this out, I'll up-date this parameter for Alpair 7 Gen 3, CHR-70 Gen.3, CHP-70 Gen 2. and CHBW Gen 1. Cheers Mark. |
| Zigmahornet with Markaudio drivers? | StevenZ | Markaudio | 13 | 26th May 2011 05:09 PM |
| FS: Fostex, MarkAudio drivers, Cabinets | ped | Swap Meet | 21 | 26th August 2010 02:25 PM |
| 5.1 system with Markaudio drivers? | Rick J. B. | Markaudio | 17 | 4th January 2010 05:53 PM |
| FS: MarkAudio Alpair 10FR drivers | cs | Swap Meet | 3 | 31st July 2009 01:44 PM |
| Page generated in 0.07113 seconds (71.95% PHP - 28.05% MySQL) with 10 queries |
