Alpair's aren't woofers - Page 9 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 24th February 2013, 03:16 PM   #81
Scottmoose's Avatar
Hardly surprising. Depends what you call 'moderate' SPLs and how far away from them you are too of course. In general though, a 5in wideband drive unit is not the speaker of choice for material with demanding LF dynamic range. There's a limit to how much air an 88cm^2 cone can shift.
Old 24th February 2013, 03:52 PM   #82
Thanks Scott. I don't usually play a lot of music with such demanding dynamic range so it was a shocker to me. Now I know.
Old 24th February 2013, 04:41 PM   #83
Bob Brines's Avatar
What kind of cabinet do you have them in? What are they tuned at? Sounds to me like the drivers are unloaded at the drum fundamental.
Bob
Old 24th February 2013, 05:24 PM   #84
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
Bob
The drums in that song hit down to 25-30Hz so no wonder the drivers are unloaded.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 24th February 2013, 07:26 PM   #85
chrisb is offline chrisb  Canada
Originally Posted by southernoise View Post
I was playing Dadawa's Sister Drum on my Pensil 10.2 thro a myref chip amp/Pass B1 buffer. At some parts when the massive drums came in the Alpairs were moving like its going to pop out of the frame. All these at moderate volumes.
that happens to be some particularly challenging program material with which I think few folks are familiar
very chilling backstory to the title as I recall
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 24th February 2013, 07:47 PM   #86
stochastic's Avatar
Originally Posted by stochastic View Post
Out of curiosity, if a pair of alpair 10's do have cone distortion inflicted upon them from excessive volume, what is the auditory result afterward? I.e. will it be noticed primarily in the hi-freq range, or will the drivers just start to fall apart faster, or... ?
I'd still love any insight into this. Maybe I'm not being clear enough? Maybe nobody knows?
Once your alpairs are damaged from over excursion and the cones show shape distortion, what is the expected result?
Old 24th February 2013, 08:37 PM   #87
frugal-phile(tm)
planet10's Avatar
Time for replacement with the old ones becoming shop templates.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th February 2013, 08:58 PM   #88
stochastic's Avatar
dave
Yes, yes, I know that the ideal is thrown out the window, but what practical changes will occur to the sound from a bent cone? Assuming that the speaker still produces sound, the voice coil isn't rubbing, etc... what is the expected auditory changes to the speaker?
Old 24th February 2013, 09:10 PM   #89
chris661's Avatar
I'd wait for Mark on the definitive answer, but here's what I'd expect:
- the frequency response of the upper midrange and treble will suddenly take on "interesting" aspects: IIRC these drivers depend on some decoupling between the centre and edges of the cone when producing HF. A big disturbance in the cone material (such as from folding) will throw the decoupling way off. I'd expect some peaks and dips to appear where new resonances form and previous ones don't form so well.
- the cone will be fundamentally damaged and so more damage will occur more easily: bending metal the first time is the most difficult - try it with a spoon!
Chris
Old 24th February 2013, 09:12 PM   #90
Scottmoose's Avatar
Depends on where you've deformed it, how badly, and what stresses have been transmitted to other areas of the cone. The behaviour will become increasingly unpredictable (not that we're starting from a known basis anyway, but you know what I mean) under dynamic load conditions.
Edit -to an extent Chris, but the MA units don't utilise this to the extent most other wideband drivers do -even the cone edges are still producing considerable resonant energy in the top octave.
Gorlich, Micro-Precision Z130 Woofers, 5", $150 Pair, Best Woofers In The World!!! NagysAudio Swap Meet 10 20th June 2012 04:49 PM
Alpair's for Near Field Monitors ljfont Full Range 10 27th August 2010 08:21 AM
Pryamid Clear Woofers or Goldwood Heavy Duty Woofers any Good? form109 Subwoofers 4 20th March 2010 08:59 PM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
