Alpair's aren't woofers - Page 6 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 27th August 2011, 09:27 PM   #51
rpnfan is offline rpnfan  Germany
Originally Posted by markaudio View Post
For example, on a Gen 2. Alpair 10, ideally the cone shouldn't move more than about 3 to 4-mm on a big roll of drum, or other similar dramatic moment in the music. For regular LF beat music, better to work on around 2-mm a guide. I've got vented boxes with Alp10's (G2) in them that make some very nice beefy bass when driver's moving around 1 to 2mm. Granted, not like subs but horses for courses, you can still get pleasing bass from a Full-ranger if the box is designed and made well and optimised for a particular driver.
Thanks Mark for the additional information. The suggestion of a maximum movement of 3 to 4 mm for a drum roll and about 2 mm for Low-Frequency-Music is meant one-way excursion I guess?
Is it correct that the excursion is critical and not the bass frequency. So when listening at low to mid levels the bass frequency can be quite low (around 30 Hz) without the danger to damage the driver? This is how I use the Alpair 10.2 in a nearfield (test) setup right now.
Old 27th August 2011, 09:53 PM   #52
markaudio's Avatar
Hi R,
Yes, its 1 way.
Yes, the excursion is critical and generating low frequencies are fine.
For those who've just joined this thread: A good optimised box design will generate low frequencies without the need for large excursions from the driver. If the driver's excursion is regularly being extended (Alpair 10, 2-mm 1 way), the box has design limitations, play volumes must be kept lower to avoid damaging the driver. This applies to most all Full-Range drivers and many smaller woofers.
Mark.
Old 22nd February 2012, 12:35 AM   #53
Is there any reasonably neutral way of "protecting" full range drivers? I'm thinking of things like accidental damage, particularly when using some bigger solid state amps etc?
I've seen references to using k to k zeners etc, but is there anything definitive on this?
Fran
Old 22nd February 2012, 02:06 AM   #54
markaudio's Avatar
Fran
Hi Fran (Guys),
As a fan of Japanese large solid state amps (Sansui, Accuphase and Sony TAF's), I realise there are various possibilities for accidental overloading the drivers. The wife/partner's enthusiastic dusting of the amp's faceplate, or kiddies twiddling the control knobs are 2 of several causes of blown drivers. I've trained myself to check the volume control every time prior to powering up.
Electrically, the recommendation will always fall on the side of matching the load to the amp's output. For example, on a 6" Full ranger around 90dB efficiency, a 50 to 70 watt class A/B solid state amp should be more than sufficient. That said, for many traditional solid state owners, 100+ watts class A/B are likely more popular.
I know several guys here in HK running large amps using CHR, Alpair 7's (mostly Gen 1's and 2's) who've added a resistor in series between the amp and driver to effect an increased load. Also, Bob Brines has mentioned protective filtering in several posts.
If like me, you wish to remain a "purist-minimalist" and not go the filter rout, then best to operate your set-up with due restraint when turning up the Volume control.
Cheers
Mark.
BTW - getting my All Japan Sony TAF-333EX back from the repairers to today! Love this amp (have 2 of them). Here's my Solid state amp collection to date:
http://www.accuphase.com/cat/e-308_e.pdf
http://www.audio-heritage.jp/SONY-ES.../ta-f3000.html
http://www.audio-heritage.jp/SONY-ES...a-f333esx.html
http://www.audio-heritage.jp/SANSUI/...lpha907dr.html
Old 22nd February 2012, 03:35 AM   #55
Bob Brines's Avatar
AH, yes! Reminds me of the Sansui 5000A and the Akai tape decks I dragged back from the Veitnam unpleasantness.
Bob
Old 22nd February 2012, 03:41 AM   #56
markaudio's Avatar
Bob
Hello Bob,
Hope you're doing well. If you wish, feel free to offer advice on protective filtering. Your knowledge on this will be likely greater than mine.
PS -I'm hunting for a Luxman L 503 (see pic) if anyone has this beast.
Cheers
Mark.
Old 22nd February 2012, 03:58 AM   #57
zman01 is offline zman01  Bangladesh
SONY TA-F3000の仕様 ソニー
SONY プリメインアンプTA-F333ESXの仕様 ソニー
SANSUI プリメインアンプAU-α907DRの仕様 サンスイ
Mark,
Nice amps!
Have you considered one of the top of the line Class-D amps like Hypex Encore or a good one based on a Tripath chipset? I guess lot of customers are trying out Class-D nowadays, and it might be worthwhile for you to expereince them with your drivers first hand?
-Zia
Old 22nd February 2012, 04:09 AM   #58
markaudio's Avatar
Originally Posted by zman01 View Post
Mark,
Nice amps!
-Zia
Hi Zia,
I'm currently testing a new class D from Derek Shek.
Cheers
Mark.
Old 22nd February 2012, 04:15 AM   #59
skeeter99's Avatar
Beautiful set of amps Mark! Really love that Accuphase!!
Scott
Old 22nd February 2012, 06:29 AM   #60
chrisb is offline chrisb  Canada
The Luxman always punched my buttons
when I was young enough, sometimes even twice in one evening
now on sabbatical
Gorlich, Micro-Precision Z130 Woofers, 5", $150 Pair, Best Woofers In The World!!! NagysAudio Swap Meet 10 20th June 2012 05:49 PM
Alpair's for Near Field Monitors ljfont Full Range 10 27th August 2010 09:21 AM
Pryamid Clear Woofers or Goldwood Heavy Duty Woofers any Good? form109 Subwoofers 4 20th March 2010 09:59 PM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 10:57 PM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 02:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ゥ1999-2015 diyAudio
