Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 25th May 2011, 04:40 PM   #1
StevenZ is offline StevenZ  United States
Default Zigmahornet with Markaudio drivers?
Hey guys, just curious. A friend of mine picked up a pair of CHR-70's a couple of days ago and since I've been eyeballing the Zigmahornet and it's glowing review on 6moons I've been curious to know if it'll work in a standard zigmahornet enclosure or if there's any variation to accomodate it.
Thanks,
Steven
Old 25th May 2011, 05:53 PM   #2
chrisb is offline chrisb  Canada
Thanks,
Steven
There are probably enclosures that can deliver more of this driver's bandwidth potential than the Zigmas - Pensil for one is a simple build.
I heard the same pair reviewed by 6moons a few years ago at a VSAC show ( 2 Bald Guys?), and they did a lot of things well, but extended, ripple free low frequency response was not among them. As I recall they were powered by a very nice 6L6 or 6V6 amp, but assisted with powered woofer for much of the demo.
For those who've actually heard the Zigmahornet with the Merrill drivers, and have a different opinion - that's fine too.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 25th May 2011, 06:10 PM   #3
Thanks for the reply Chris. I wonder how it sounds with the Fostex drivers or Markaudio since you can no longer purchase the Merill's. I was mainly interested in them due to their very small footprint. Perfect for tight places where floor-estate is sparse.
Old 25th May 2011, 06:45 PM   #4
frugal-phile(tm)
planet10's Avatar
<rant>
The Zigmahornet has only 1 redemming value -- the tall skinny format is aesthetically pleasing.
Put printouts of all the diy FR designs on a wall. Blindfold yourself. Throw a dart at the wall. If you actually hit a design the probability is very high that you'll stick a better design (sonically)
The Merrill DCA4 worked because: 1/ it has a quite high Q (>1) and wants to see as large a box as possible. 2/ it has a high Fs (100 Hz plus) and does not go low enuff to excite the overlong column if the ZHornet.
Trying to use a driver that actually gets close to exciting the column will start showing the box for what it is.
</rant>
I think you would also find that the CHR won't fit on the baffle without sticking out.
Pick a driver and build a box designed for that driver.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th May 2011, 06:59 PM   #5
For a single pair of CHR70s, either the Pensil, or mono-driver version of P10 MT would be on my short list . While my favorites are fairly well know, all of Mark's drivers I've heard to date deserve enclosure designs that extract their full potential.
The Zigma might be suitable for the A6, provided they could be shoehorned into the very narrow baffle, but as Dave notes, they'd probably need to be crossed over high enough to a pair of woofers to disguise the enclosure's design shortcomings.
Old 25th May 2011, 07:27 PM   #6
Thanks guys. Advice taken. CHR70 Pensil has already been drawn, processed and is ready to cut on my CNC. If my buddy doesn't like them and decides to go another enclosure route, I'll build them for myself. Assuming the new CHR-70 version 3's will work in the same enclosure as Mark has stated in another thread.
Old 25th May 2011, 09:01 PM   #7
frugal-phile(tm)
planet10's Avatar
Originally Posted by Andrewbee View Post
diyparadise sells the Merrill drivers.
I believe the situation is more like: they sold all the remaining stock, and now have something completely different.
dave
Old 25th May 2011, 09:32 PM   #8
dave
Whichever the case may be regarding the "Merrill" drivers, the issue remains that Stevenz's friend already has the CHR70s, for which the Zigma enclosure is not likely a good match
Old 25th May 2011, 10:02 PM   #9
frugal-phile(tm)
planet10's Avatar
CHRs dropped into Zigma drawing.
dave
Old 25th May 2011, 10:53 PM   #10
Meh, nothin' a good belt sander can't fix. Haha!
FS: Fostex, MarkAudio drivers, Cabinets ped Swap Meet 21 26th August 2010 02:25 PM
5.1 system with Markaudio drivers? Rick J. B. Markaudio 17 4th January 2010 05:53 PM
Pair of Merrill DCA4 drivers - Zigmahornet boudy Swap Meet 1 22nd October 2009 12:37 PM
WTB Fullrange Drivers Fostex, Markaudio etc sts9fan Swap Meet 0 29th September 2009 04:26 PM
FS: MarkAudio Alpair 10FR drivers cs Swap Meet 3 31st July 2009 01:44 PM
Page generated in 0.09928 seconds (82.14% PHP - 17.86% MySQL) with 11 queries
