Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 10th May 2011, 06:30 PM   #1
frugal-phile(tm)
planet10's Avatar
Default Compact Enclosures for Alpair 6M
The goal for these was the smallest size enclosure possible with at least a modicom of bass. Sims suggest <80 Hz (volume limited by size/excursion).
Neither of these have been built yet, The slot port version is the 1st cut at a nMar-Ken6M. drawn with 12mm material, good multiply recommended.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th May 2011, 06:54 PM   #2
Scottmoose's Avatar
Neat. I like the 2nd one in particular.
Old 10th May 2011, 07:10 PM   #3
EUVL is offline EUVL  Europe
If it only goes to 80Hz, wouldn't it be better to leave it sealed and cross 1st order with a sub ?
Patrick
Old 10th May 2011, 07:16 PM   #4
frugal-phile(tm)
planet10's Avatar
Depends on the goals & needs. These do get you low enuff to XO to a sub.
If sealed a sub wouldn't do it, you'd need a pair of woofers. They should be excellent as a mid-tweeter.
dave
Old 10th May 2011, 08:52 PM   #5
skeeter99's Avatar
Nice Dave! 80hz would make these excellent surrounds or even as mains in a smaller system. Very cool!
Old 10th May 2011, 09:10 PM   #6
frugal-phile(tm)
planet10's Avatar
Looked at the sims again... 80 hz might be a bit optimistic, 70 Hz F10, slot port should get you a bit lower with a bit less bump than the round port. The uMar-Ken6 (which accomodates either A6P or A6M) is about 60% larger should get you to the magic 80. The full-size miniOnken for A6M looks like it will be based on 3.5-3.6 litre (still in development)
Chris is working on a set of sealed rear surrounds....less than a litre. To be used with (existing) Pensil7 LR & dMar-Ken7 centre
dave
Old 11th May 2011, 04:43 AM   #7
chrisb is offline chrisb  Canada
dave
well, he's still looking at the drawing and brainstorming* the easiest way to fabricate an mirror imaged pair of enclosures with compound angles
I bet no nails and the 12" slider figure into it somehow
(*considering the remaining computational power, you'd only need a windbreaker )
BTW, an all Alp7 front row with dual woofer arrays, XO'd at 90Hz is is pretty nice little set up for a smallish (320sq ft) room
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 9th September 2011, 05:12 AM   #8
Any updates?
Old 9th September 2011, 05:36 AM   #9
frugal-phile(tm)
planet10's Avatar
We built the big enclosure (3.6L) for the A6M. Works well.
3" driver audition Fostex/Mark Audio
dave
Old 9th September 2011, 06:19 AM   #10
zman01 is online now zman01  Bangladesh
320 sq ft is smallish?? Maybe in the North American continent , but most places elsewhere it would be considered largish I guess.
-Zia
Edit: Probably we can lose the "ish" is largish
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 9 25th April 2011 09:05 PM
Alpair 6M Gen. 2 (metal) introduction markaudio Markaudio 62 29th March 2011 04:44 AM
Alpair 12, Alpair 6M wushuliu Swap Meet 5 11th February 2011 07:33 AM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 05:04 AM
milliSize enclosures released for CHR-70, Alpair 6 and EL70 planet10 Markaudio 0 29th October 2009 07:48 AM
Page generated in 0.10060 seconds (78.80% PHP - 21.20% MySQL) with 11 queries
