#21 |
frugal-phile(tm)
You might consider the Classic GR Mar-Ken12 on its side with the driver centred horizontally.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#22 |
Will moving the driver to the center of the box affect the sound in some way? I presume you designed it offset to one side and up toward the top for a reason or was it for aesthetics? Thanks Dave.
Scott |
#23 |
frugal-phile(tm)
Driver is offset to help spread the diffraction signiture. Put it into a typical centre channel situation and that is moot. I'd leave it offset to the (new) top or bottom. It can then be oriented to get closer to the height of the mains.
dave
#24 |
Cool thanks for the tip Dave! What's -3db on the GR-12?
#25 |
frugal-phile(tm)
Estimated F3 ~70 Hz, F10 45 Hz.
dave
#26 |
That'll work well for HT down point. Just need to get my first cabs built, make sure I like them then order up another driver. Hopefully I can still get another Copper A12 when I go to order
Scott |
#27 |
Its been a while since I've been able to do any work and finally was able to get over to my parent's where my dad has a table saw. We got all the boards cut except the braces and got one of the cabinets mostly glued up. Just have the cleats and the back left. Gonna get the other all glued up tomorrow so hopefully can get these at least making sound before the weekend is over. Here's a couple pics at least of the progress
#28 |
Cool Scott, looks like you'll beat me to it! Are you doing the braces, or skipping them?
I am also geared up for the veneering this Sunday, followed by the color/finish later in the week. Keep the updates coming. -Zia |
#29 |
Zia,
I'm planning on doing the braces but want to get it up and running first before I do those. Since this is my first FR system I don't want to spend tons of time on the "finishing touches" if I'm possibly not going to like them. I hate to sound negative but coming from pretty high end multi-driver systems I'm still a bit cautious. I only have room for one system so I need to make sure I really like them before I spend a ton of time doing all those finishing touches. Given what I've heard so far I am really going to like them so I doubt it'll be an issue Keep yours going, you'll get them done!! Can't wait to see your pics too!! Scott |
#30 |
One cabinet pretty much done. Started sanding and its SOLID and HEAVY! Wow, this sucker is really going to be very heavy when its done!! Going over to the rents tomorrow morning to glue up cabinet #2 and get the holes cut in the fronts of cabinet #1 and 2. Should be fun! We're also going to do a lot of sanding (wearing masks of course) so we're REALLY going to make a lot of dust!! Great start to a Saturday
Scott |
| Thread Tools | Search this Thread |
| My first build | tangmonster | Subwoofers | 12 | 10th June 2010 09:01 AM |
| What would you build? | croat47 | Subwoofers | 27 | 22nd September 2006 04:57 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| How to build. a | jleaman | Digital Source | 5 | 18th August 2003 03:06 AM |
| Page generated in 0.10594 seconds (79.85% PHP - 20.15% MySQL) with 11 queries |
