#11 |
Thanks Mark, just wanted to make sure. Are most people soldering their wires on to the terminals? I'm guessing that's the case ... I just have spades connecting the wires right now but that's just for break in.
#12 | |
No worries, soldering is the nice way to go. Or, I did see some nice gold plated spade connectors from Japan but not sure where they can be bought. If you're soldering your Alp12's, use a good flux to clean the terminals and cables. Pre-solder terminals and cables, it fixes so much better when you come to main solder cables to connectors. Apply just enough heat to get the solder running, remove the iron immediately. Cheers Mark. |
#13 | |
Scott |
#14 |
Built some temporary OB housings for the 12's just so I could get them in the living room and hear them in a little better environment
Scott |
#15 |
Looking good Scott, just make sure your little one doesn't have a poke!
-Zia |
#16 |
#17 |
So what options are there for an Alpair12 center channel? I've seen THIS one but don't know any of the specs of the 12 in this box. I'd really like a -3db of around 80hz for crossover to my sub and prefer a large center channel (my current is 36"W x 8.5"T x 16"D). Does anyone know or has seen the modeled response for the center channel I linked to? What about other larger options?
Thanks! Scott |
#18 |
frugal-phile(tm)
Sealed is only going to be good to about 100 Hz.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#19 |
#20 |
frugal-phile(tm)
I will be, but haven't yet.
dave
| Thread Tools | Search this Thread |
| My first build | tangmonster | Subwoofers | 12 | 10th June 2010 09:01 AM |
| What would you build? | croat47 | Subwoofers | 27 | 22nd September 2006 04:57 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| How to build. a | jleaman | Digital Source | 5 | 18th August 2003 03:06 AM |
| Page generated in 0.10602 seconds (81.77% PHP - 18.23% MySQL) with 11 queries |
