Submitted for your approval, ideas encouraged for next gen A12.2 production run work in progress:
1) sensitivity to break the 90db barrier for the "Deep triode" low watt club members, without giving up to much of it's current attributes 2) less of a peak in the 7khz- 10khz range of the current model 3) 8Ω ohm impedance 4) Fs ≤50 Hz for full range use without the need for a sub 5) similar TS parameters as current A12 to allow for drop in or slight modifications to current cabinet designs 6) Alnico magnet |
#2 |
how about Neo magnets?
its light. cheers henry |
#3 | |||||
frugal-phile(tm)
I'd be happy to see the same driver with more finesse (ie 3d sounstage closer to A7). This could come with as little as the spider improvements already underway, and the voice coil tech from the A10.2, dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | |
Good points you make. Can you please elborate the end-customer/listener benefits you are expecting by improving the voice coil tech and spider? What about paper cones? I hear the CHP-70 and EL-70 are awesome. -Zia Last edited by zman01; 13th April 2011 at 08:25 AM. |
#5 | |
frugal-phile(tm)
dave
#6 | |
Dave, i like your suggestions. I didn't know the A10.2 had a different spider then the A12. Was thinking about the spider Seas uses in their fullrange driver but thought i was already pushing it requesting Alnico. I had vaguely remembered Mark describing the possibility of the coil upgrade in a previous post so did a search and found it:
#7 |
V. little time, but a couple of brief thoughts on magnets:
-AlNiCo per what Dave said. Excellent properties (so long as you look after it) but it costs a heck of a lot, so it would likely end up as a high priced model with different design objectives / physical properties etc. -Don't like neodymium much from an engineering POV. Unless there is a very good reason to use it (e.g. a requirement for huge motor strength & cost no object) I'd rather have a good ferrite. A lot of what is said re. magnets is marketing waffle anyway. It's less about the material & more about how it's used. |
#8 |
Scott, Dave,
Any commments on paper vs aluminium or that is a moot discussion with a Speaker like Alpair 12 or 10? Btw, good to see Scott posting again. -Zia |
#9 | |
Mark has obviously invested much of his engineering and production expertise over the past several years in advancing metal cone wide-band drivers, but one can only imagine what he could achieve with some of the more exotic paper formulations that are currently fashionable.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#10 | |
frugal-phile(tm)
Many of the neo motors and not taking advantage of its character... one has to rethink motor design to max it out. Expect new magnets to come out of current tech work being done for wind generators, electric motors, etc. dave
| Thread Tools | Search this Thread |
| Alpair 10 Gen. 2 introduction | markaudio | Markaudio | 183 | 17th December 2011 01:35 PM |
| Subwoofer for Alpair 10 Gen.2 | Alex_77 | Markaudio | 1 | 25th March 2011 06:48 PM |
| Alpair 6 - Gen 2. - Prototype 1 | markaudio | Markaudio | 53 | 11th November 2010 04:18 AM |
| Alpair 12 - Gen 2 | otto88 | Markaudio | 2 | 30th September 2010 04:06 PM |
| When is the alpair 10 gen 2 coming out ? | norman bates | Markaudio | 10 | 1st March 2010 10:22 AM |
| Page generated in 0.12588 seconds (84.16% PHP - 15.84% MySQL) with 11 queries |
