Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 11th May 2011, 01:36 PM   #21
mp9 is offline mp9
Originally Posted by markaudio View Post
may be possible to make a 6.5" uber low mass paper cone, less than 500 micron thick, with a wide stable profile......
We have a meeting next week so lets see what happens.
Cheers
Mark.
...keeping my fingers X'ed
Old 12th May 2011, 06:55 AM   #22
wushuliu's Avatar
Originally Posted by planet10 View Post
Generally i have liked paper. Mark has redifined what can be done with metal.
I'll comment on Mark's metal vrs paper after i get a chance to hear the A6.2s
dave
Any comments on this yet, Dave? You've been cooking those guys for a while now!
Old 12th May 2011, 07:05 AM   #23
wushuliu's Avatar
Cheers Scott,
There is a "chink" of light re the +90 dB classic 6.5" paper coned full range drivers. I have a good friend in HK, Michael works at a cone makers. We reckon it may be possible to make a 6.5" uber low mass paper cone, less than 500 micron thick, with a wide stable profile......If we can pull this trick off, his boss said he may be willing to invest in the project and run the production. They'd build the driver and use it in finished systems, I design the driver and sell it to Diyers and small builders. We have a meeting next week so lets see what happens.
Cheers
Mark.
Fingers crossed. As good as they are, I prefer the paper drivers (EL70, A6P) over the metal cones.
Old 12th May 2011, 07:50 AM   #24
frugal-phile(tm)
planet10's Avatar
Unfortunately they are sitting waiting. paid for drivers keep jumping them in the queue.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th May 2011, 07:26 AM   #25
zman01 is online now zman01  Bangladesh
Originally Posted by Scottmoose View Post
Now that could be very interesting. I'll look forward to seeing how that pans out.
Originally Posted by chrisb View Post
so say we all
Yes, and all the best!
Old 16th May 2011, 08:29 AM   #26
In response to the original question, some challenging yet achievable objectives might be:
Sonic: Alpair 10.2 with improved dynamics and and composure (ie. the common benefits of increased cone size, vis-a-vis the 10.2)
Practical: efficiency of > 90 db efficiency (not slightly under), preferably up ~ 92 db. This would make it useable with some of the better SET amps in a wider range of systems/rooms.
Other: Special additions using perhaps paper cones and AlNiCo magnets - this would not be important to my buying decision (though I would buy one if avail).
Raymond.
“We must have concepts in order to function; they are not the problem. The problem is created when we believe they are the truth.” Charlotte Joko Beck
Old 16th May 2011, 07:18 PM   #27
frugal-phile(tm)
planet10's Avatar
Alpair selection...
3.5 watts in my big room we only started noting (small) issues with the 84.5 dB A7.
dave
PS: note that i updated the thread title.
Old 17th May 2011, 10:02 AM   #28
Hi Dave,
As always, thank you for sharing your experience; people here, myself included, very much appreciate your substantial ongoing contributions.
I am not sure how significantly your listening experiences translate to my wants / objectives. I do not know the size of your room (Edit: just got some idea from a thread that was linked from the linked thread!), the music that was listened to, or how loudly.
You - ant it seems that many listeners on your continent - describe music reproduction largely using visual cues and things that can be explained using visual analogies, eg. sound-staging, detail, DDR/resolution etc. I most frequently read comments using these visual descriptions. This is not a criticism(!); it is an observation... and there are likely a number of reasons for this (convenience, cultural preferences, driver strengths...)
Visual aspects matter to me as well, but are less so than musical flow / nuance, tonal presence / texture (not "warmth", per se), poise, balance and an absence of aberrations that return me to being consciously aware I am listing to a reproduction system (ie. bass modulation of other frequencies, gross compression and glare). Most importantly, when I listen to music I simply want to experience it - I don't want to think / analyse / critique and I don't need to recreate an event.
I also prefer to listen at lowish to moderate levels with high quality, low power amps. That the Mark Audio drivers seem to work adequately with lower power amps, perhaps their musical communication / presence is excellent at lower levels, therefore not requiring loud volumes for satisfaction (which I would like!). But, I am not convinced (yet) that amps with power as low as 3.5W will cut it with any Mark Audio driver in a moderate sized room.
Sorry for meandering OT. In short, I would like a Mark Audio driver that could meet my needs. From the comments I have read - most of which are (very) positive - I am not yet confident one - in this case the current A12 - can. I hope one day I can be confident...
Raymond
Old 17th May 2011, 08:35 PM   #29
frugal-phile(tm)
planet10's Avatar
Room is described (with 3D visualizations & pictures) here: http://www.diyaudio.com/forums/blogs...ing-space.html
We typically listen at levels of 80-85 dB at the listening position (less late in the evening). The last session including some classical, jazz, rock, and the obligatory Loreena McKennet.
You want to get lost in the music, to get an emotional connection with the music.
The term DDR is a physically definable term i use that is the key to many of the things you describe. More DDR gives you more of the very subtle clues which define a space, clarify the nature of an instrument or voice, sync the timing and flow of the music.
One can just start out with one of the modestly priced drivers and get a good taste for what the more expensive ones offer. There are no words that can really adequately explain what something sounds like.
Remember, just like cookies, it is hard to just have one. Free yourself of anxiety, start on a budget, get a taste. Everone always needs a 2nd set of speakers, or has a friend/relation that has a need for your learning experiences.
dave
Old 18th May 2011, 09:13 AM   #30
Thanks for that Dave. I probably listen at similar levels; occasionally louder but often more quietly in the late evening... Harold Budd, Loscil, Stars of The Lid, Yui Onodera, Marconi Union, Beautiful Schizophonic and other quiet music while reading.
Yes, very often. People's emotional cues differ, so I rarely mention it and instead try to understand and describe the sonic cues that lead to this as adequately as I can. But, as you go on to say, we cannot adequately describe music - or its reproduction - in language. As soon as you try, it is lost. Which brings me to my next point, "experiencing" (or "awareness) is a little different to emotional connection, but that is not for the forum
So, it is like minimising self-noise to reveal true resolution, rather than sonic enhancement / shaping / artificing that gives the initial impression of hyper clarity or resolution, yet we sense is artificial, in time. An absence rather than an addition. Zen, in a way. BTW, I am rather sensitive to "enhancements", which is why I think the current A12 may not be ideal for me. Thus my comments that I would prefer a presentation closer to the A10.2.
I understand what you are saying Dave - there is no substitute for experience; the wider the exposure the better. However, my DIY interest is more in amps rather than 'speakers, so I will not want to churn them over too often. I am happy to research as best I can, purchase well (but not crazy expensive), then tune.
That said, I would like an intimate non-critical system for the study / man-space, so may try a small Mark Audio driver driven by a 6L6 in SE Triode (or 6V6 SE in triode / ultralinear). Low cost and should sound decent in a small space. Oh, and then there is the bedroom... Ah, I see your point about cookies!
Thanks again Dave.
Raymond.
Alpair 10 Gen. 2 introduction markaudio Markaudio 183 17th December 2011 01:35 PM
Subwoofer for Alpair 10 Gen.2 Alex_77 Markaudio 1 25th March 2011 06:48 PM
Alpair 6 - Gen 2. - Prototype 1 markaudio Markaudio 53 11th November 2010 04:18 AM
Alpair 12 - Gen 2 otto88 Markaudio 2 30th September 2010 04:06 PM
When is the alpair 10 gen 2 coming out ? norman bates Markaudio 10 1st March 2010 10:22 AM
Page generated in 0.13982 seconds (83.22% PHP - 16.78% MySQL) with 11 queries
