CHR-70 GENERATION 3 - COMING SOON - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th March 2011, 08:59 PM   #31
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Originally Posted by Scottmoose View Post
Extra efficiency would be a bonus, but I am strongly opposed to a drop, just to obtain a couple of extra watts of power handling. The CHR is already a relatively low efficiency unit & I don't think it can really afford to loose any.
Absolutely!
Old 6th March 2011, 02:38 AM   #32
markaudio's Avatar
Hi Guys,
This members who'd like to chat more specifically on Amp voltage/current etc., I've made a new thread for you:
Amps - voltage/current discussion
I've migrated the relevant posts from this thread to the new. Apologies if I've missed any posts that should be moved.
In the meantime, please feel free to post more about the new CHR-70 on this thread.
Cheers
Mark.
Old 6th March 2011, 02:39 AM   #33
germpod is offline germpod  United States
I am in the camp that would prefer higher efficiency vs lower efficiency, along with being 8 ohms if possible. The QTS seems fine for both vented and sealed enclosures, so I would leave that where it is.
I may be wrong on this, but I am under the impression that most of the DIY full range audio people are using low powered amps in the form of Tubes, T-Amps, Gainclones, or First Watt clones. Lower efficiency would exclude all of those users, and the drivers would seem to be mostly usable by the home entertainment people (though that is a sizable market).
Making it 8 ohms makes it so you can use two drivers to get an extra 3db of efficiency which is quite appealing, to go along with the other benefits of using two drivers.
Ed Robinson
Old 6th March 2011, 02:45 AM   #34
markaudio's Avatar
Hi Guys,
Summarising so far we have................
1 - OK having a more rigid frame
2 - OK having a new cap
3 - Cotton spider with No.2 coil connection is looking OK
4 - Power handling around 20 watts (nom) is still OK
5 - A bit more SPL would be welcomed
6 - An 8 ohm version would be welcome
Please feel free to keep feeding back. Please encourage members on the full-range section to joint in. Now is the time to place opinions.
Mark.
Old 6th March 2011, 02:48 AM   #35
markaudio's Avatar
Ed Robinson
Hi Ed, Guys
Thanks for your thoughts
Question.......Should I only make the new CHR in 8 ohm (drop the 4 ohm coil)?
Please feel free to encourage more replies (thanks)
Mark.
Old 6th March 2011, 02:49 AM   #36
I am also under the impression that lower efficiency drivers are less capable of good dynamics then high efficiency drivers, though I have not verified if that is true or not. I have read it on the forum in the past though, and know that other people share that impression.
Ed Robinson
Old 6th March 2011, 04:03 AM   #37
frugal-phile(tm)
planet10's Avatar
The CHR is attracting a whole bunch of people using typical Japanese receievers and even thou they have low measured efficiency (i've gotten a touch over 82.5 db 1W/1m (T/S)) there are people happily using very low power amplifiers (3.5w)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th March 2011, 04:07 AM   #38
frugal-phile(tm)
planet10's Avatar
Where the fixing holes moved so that they aren't so close to the driver cutout?
dave
Old 6th March 2011, 04:16 AM   #39
Scottmoose's Avatar
Re dynamics, depends on the drive unit in question. Dynamic BW is related to efficiency, power handling & linear powertrain deflection. You can have an HE unit with very little Xmax, and therefore it will have a relatively low linear dynamic BW. Conversely, you could have a drive unit with a little less efficiency, but significantly greater powerhandling & Xmax, which may have a wider dynamic range than the nominally HE driver.
All other things being equal the higher the efficiency the better. Problem is, it's almost impossible to only change efficiency & keep all other factors equal, so we're back to picking the compromises that best suits a given set of requirements.
Mark -I again strongly urge that the Gen.3 driver should be consistent with the current Gen.2 model in basic spec. (in T/S terms, Q, Vas & Fs as close as possible to the existing unit). If it significantly departs from these, remember that all the existing box designs for the CHR will need to be redesigned, and in many cases completely scrapped and new ones developed from scratch. As a wide variety of available projects tends to help unit sales, it's something to keep in mind.
Old 6th March 2011, 04:19 AM   #40
Scott,
Thank you for the clarification :-) It seems in audio it always comes back to what compromises make the most ideal situation for you in your room.
Ed Robinson
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 06:02 PM
New CHR-70 markaudio Markaudio 68 3rd February 2011 02:44 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 02:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 12th January 2010 12:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
