CHR-70 GENERATION 3 - COMING SOON - Page 28 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 17th June 2011, 02:47 PM   #271
Originally Posted by markaudio View Post
Try your winzip and other software, you'll get a nice box design for this CHR.
Mark
Can you clarify "Winzip", I would like to know the software package you meant?
Thank you
Miles
Old 17th June 2011, 03:42 PM   #272
Squeak is offline Squeak  Denmark
Squeak's Avatar
Originally Posted by MilesCampbell View Post
Mark
Thank you
Miles
I believe it is a compression/decompression widget for the ailing Windows platform. What you were supposed to winzip I don't know.
Old 17th June 2011, 03:57 PM   #273
tuxedocivic's Avatar
I think he meant to use winisd - LinearTeam
It's a box modelling program. I personally use unibox - UniBox - Unified Box Model for Loudspeaker Design - Kristian Ougaard
Because it's an excel spreadsheet and I didn't want to install ANOTHER modelling program on my computer. I think winisd is more powerful though. Haven't used it so I can't say for sure though.
Old 17th June 2011, 04:11 PM   #274
Here's a quick unibox plot:
Warning, pretty much no thought went into this. It's not necessarily a good design :P
Old 17th June 2011, 06:26 PM   #275
frugal-phile(tm)
planet10's Avatar
design :P
A tip. I like to keep the 1st derivative of the modeled curve from changing sign more than once. You have a dip at 55 Hz (?) that violates this guidline. Means the box is too big or the tuning too low or both.
You will get a lower F3 but along with, the flabby, ugly kind of bass that gives BR a bad name.
So far in mine (& Scott's) modeling CHR70.3 pretty much drops into all the old boxes but in extreme sizes some tweaking is beneficial*. I would suggest a BR box size of just under 5-10 litres (* with the 70.3 i am comfortable venting a milliSize, whereas i left them sealed before)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th June 2011, 06:28 PM   #276
frugal-phile(tm)
planet10's Avatar
Hi Guys,
Here's an old plan that now likely needs modification.
Pensils: The range of Pensils have all been updated for the latest drivers. The single sheet summary should be posted later today, the comprehensive document is not far behind.
dave
Old 17th June 2011, 06:38 PM   #277
That's basically why I put that warning. I saw some other saying 11 to 14L so I put in 12 and ask the calculator to figure the rest. Thought it looked ugly, hence the warning.
I was more interested in this:
Because I already have an 8.6L box with that tuning. Just need to make a new baffle for it. Looks pretty decent considering I already have the box and a new baffle is easy.
EDIT - The label in the picture says Fountek, but it's for the CHR70. Just didn't change the label when I modelled it.
Last edited by tuxedocivic; 17th June 2011 at 06:42 PM. Reason: Picture clarification
Old 17th June 2011, 06:46 PM   #278
frugal-phile(tm)
planet10's Avatar
That is quite close to the CHR-Ken volume & tuning. It wouldn't hurt to shorten the port a bit (raise the tuning)
dave
Old 17th June 2011, 06:50 PM   #279
dave
I was looking at that, if I were to use those cabs. But I'd still want to keep the cabs tuned for the project they were intended for. It would just be convenient.
Old 17th June 2011, 07:04 PM   #280
Right now I'm spinning between CHR, EL70, and Alpair 7
I want to try a purist approach with one of these 4". Alpair 7 is pushing the budget, but looks SOOOO good. Already love the EL70. Will have to wait for VI DIY Fest to be convinced
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 05:02 PM
New CHR-70 markaudio Markaudio 68 3rd February 2011 01:44 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 01:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 11th January 2010 11:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
