CHR-70 GENERATION 3 - COMING SOON - Page 24 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th June 2011, 05:59 PM   #231
EUVL is offline EUVL  Europe
See PM.
Patrick
Old 15th June 2011, 04:52 PM   #232
markaudio's Avatar
Hi Fellas,
Here's the final mass production data for the CHR-70 Gen.3's.
This is the first time I've make a lower cost Markaudio driver (aside the EL70) that gets to 25-kHz. Overall, its a nicely improved driver over the Gen. 2.
The output from the power-train is a significant improvement. I've managed to move the peak up to HF range so its well outside the most sensitive parts of the spectrum. This driver's Fo is lower (65Hz) while maintaining a total Q of 0.55. Try your winzip and other software, you'll get a nice box design for this CHR. You're getting even more "bang for your bucks" so to speak.
Technical improvements are:
1 - stiffer frame.
2 - new cap design with new improved fitting method.
3 - new Japanese designed coil.
4 - new spider for improved bass (3060).
5 -2 colour choice (champagne gold and and brush look metal cones)
Take a look at the data, I'll post more later and make information PDF's soonest possible.
Cheers
Mark.
CHR-70 Gen.3 Data
REVC 7.2 Ohm
Fo 65.40 Hz
Sd 5.02 K mm/2
Vas 5.17 Ltrs
Cms 1.44 uM/N
Mmd 3.90 g
Mms 4.10 g
BL 4.20 G/cm
Qms 2.66
Qes 0.69
Qts 0.55
Levc 32.44 uH
No 0.20%
Spl 85.4 dB
Pwr 20w Nom.
X max 4-mm 1 way
Coil Dia 20-mm
Main tolerance +/- 2.5 hz on mean Fo
File Type: jpg CHR-70-gen3-fr0_15_30-june2011-smla.jpg (172.2 KB, 234 views)
Old 15th June 2011, 04:55 PM   #233
markaudio's Avatar
Hi Fellas,
Here's the pics:
Cheers
Mark.
Old 15th June 2011, 04:58 PM   #234
Looks awesome and I hope it will sound awesome as well. Sign me up for three (r/c/l) as soon as they hit the US. Thanks for all of your sharing Mark.
Old 15th June 2011, 05:00 PM   #235
Beautiful, sir! Is it just me, or has the pressure to increase impedance and SPL reduced the amount of built in BSC, or even eliminated it?
...And will you be posting info on the CHP-70 anytime soon?
Old 15th June 2011, 05:01 PM   #236
zman01 is offline zman01  Bangladesh
Thanks Mark, new CHR-70 looking good.
Anything on the new CHP-70?
-Zia
Old 15th June 2011, 05:13 PM   #237
markaudio's Avatar
Hi Chaz
A little less so. The correction is now wider. I've spent more time flattening out much of the frequency range. Reason being the total range has increased by some 15%, thus I needed to increase stability in the power-train (lots of late nights working on this design challenge).
With 65Hz and a total Q of .55, you'll get nice bass so in most box designs, no need for any correction.
About to post CHP results.
Cheers
Mark.
Old 15th June 2011, 05:15 PM   #238
Scottmoose's Avatar
It's still there to an extent although the balance has clearly shifted toward something more akin to the Alpairs. It's a broader band lift this time, if slightly shallower, so it may end up being more effective than previously. The off-axis behaviour appears to be stable, with a gentle HF roll-off, which should help.
I suspect a case of watch this space over the next day or so.
Old 15th June 2011, 09:43 PM   #239
Bill poster's Avatar
Hi Mark, I want to use these in a TL but because of the high qts and good bass response I am not sure what length line- close to Fs as normal or much lower?
Old 15th June 2011, 10:16 PM   #240
frugal-phile(tm)
planet10's Avatar
Rarely a good idea to tune any TL to below Fs.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 06:02 PM
New CHR-70 markaudio Markaudio 68 3rd February 2011 02:44 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 02:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 12th January 2010 12:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
