CHR-70 GENERATION 3 - COMING SOON - Page 18 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 15th May 2011, 06:49 AM   #171
Lerg is offline Lerg  Canada
Looking at all of the images that have been posted, that cap has a pointed nose, its conical.
Old 16th May 2011, 03:08 AM   #172
zman01 is offline zman01  Bangladesh
Originally Posted by markaudio View Post
Hi Guys,
Norio and me had time for a new CHR Gen 3 listening session last Friday evening. We were very very happy chaps. The Gen 3 model is a nice step forward. You're going to get allot more a everything (acoustically speaking).
Scott and Dave have kindly checked the T/S data, confirming the Gen 3 is OK to retrofit for those guys who want to swop out the old models.
Cheers
Mark.
Mark,
Great that production hiccups are over and you are good to go!
Bring 'em on!
-Zia
Old 17th May 2011, 03:24 AM   #173
italynstylion's Avatar
When do you suspect these new models will hit the retail shelves?
www.StereoClarity.com
Old 17th May 2011, 03:49 AM   #174
frugal-phile(tm)
planet10's Avatar
The rule-of-thimb i have been using is 6-8 weeks after the production run is done.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th May 2011, 06:43 AM   #175
ttan98 is offline ttan98  Australia
Mark,
What would be an ideal size(or range of sizes) of a sealed enclosure to house the new CHR70 Gen3?
I have a set an enclosure which may be able to house them.
Old 17th May 2011, 07:30 AM   #176
frugal-phile(tm)
planet10's Avatar
Sealed sims based on the numbers from test builds using production parts.
From these, sealed can be quite a wide range.
dave
Old 17th May 2011, 11:02 PM   #177
Dave,
Thanks for your diagram.
Mark,
Will you be selling Chr70 mk 3 direct to users similar to Alpair 10.2 as an initial offer?
Old 18th May 2011, 02:10 AM   #178
markaudio's Avatar
Originally Posted by ttan98 View Post
Dave,
Mark,
Yes, can do. Dan (Archer Audio) hasn't been in touch with me so I'll direct sell until he stocks. Email me - support@markaudio.com
Cheers
Mark.
Old 18th May 2011, 02:14 AM   #179
markaudio's Avatar
Hi Guys,
A quick note to let you know CHR-70 Gen 3 new coils are in from the Japan maker. We plan to final assemble commencing Thursday 26 May. Should take around 4 to 5 days. Will keep you informed.
Mark.
Old 26th May 2011, 03:06 AM   #180
markaudio's Avatar
Hi guys,
We're ahead of our build schedule. Take a look at the pic. That's the new look CHR-70 Gen. 3 hot off the production line. Note the change in the cap fix arrangement. We have further reduced the glue volume by designing a new jig. The method is a departure from previous where we fitted the cap and applied an external ring of glue. Now we machine apply a ring of bond on the inside of the cap, then fit it to the top of coil.
3 main advantages of the new method:
1 - The cap seal is far more reliable. We can direct check the ring bond on each individual cap prior to fitting. This ensures a 100% seal. The old method had a 12% seal error rate, now less than 2%.
2 - We use 50% less glue with this method, further help on reduce power-train mass.
2 - It looks much better than the old method.
More information coming in the following days.
Cheers
Mark.
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 05:02 PM
New CHR-70 markaudio Markaudio 68 3rd February 2011 01:44 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 01:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 11th January 2010 11:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
