CHR-70 GENERATION 3 - COMING SOON - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 11th March 2011, 08:58 PM   #101
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Originally Posted by Scottmoose View Post
Yes, I'm perfectly aware of what it was for; and given that it follows the Fletcher-Munson / Equal loudness curves rather well, it also makes for a logical scientific definition of what constitutes the critical hearing BW (nee 'midband'). The point is, avoiding an XO within ~an octave either side of this region is desireable if at all possible & if a compromise needs to be made, you're generally better off doing so on the bottom end; for e.g. shifting to 500Hz to improve powerhandling (based on the power distribution of typical large orchestral pieces, rock music &c.)
I can't keep track of what everyone knows.
Fletcher-Munson is not Robinson-Dadson.
http://www.sengpielaudio.com/Fletche...son-Dadson.pdf
Old 11th March 2011, 10:08 PM   #102
markaudio's Avatar
Hi Guys,
Maybe its just regular exposure of listening to full-range drivers, but those times when I listen to multi-way systems, to my ears the music appears to be cut into chunks. The mid-highs sounds disconnected from the lower forms of the music.
I'm not knocking multi-way. Indeed I worked quite hard on Woof No.6 and Tweet N0.3 to help "smooth" such phase issues. But I've become used to listening to extended full-range drives where phase differential is pretty much a non-issue, that the music sound more real to me, as though I'm at the concert. I'm I going crazy?
Cheers
Mark.
Old 11th March 2011, 10:19 PM   #103
AEIOU's Avatar
Originally Posted by markaudio View Post
Hi Guys,
I'm not knocking multi-way. Indeed I worked quite hard on Woof No.6 and Tweet N0.3 to help "smooth" such phase issues. But I've become used to listening to extended full-range drives where phase differential is pretty much a non-issue, that the music sound more real to me, as though I'm at the concert. Am I going crazy?
Cheers
Mark.
Yes, you are one "Wild and Crazy Guy."
Old 11th March 2011, 10:43 PM   #104
Scottmoose's Avatar
In that case, perhaps you could in future remember that some of us do actually know what we're talking about. Thanks awfully.
Sigh. I assume you failed to observe the '/' in my post, signifiying, as is generally appreciated, 'either / or.' And the use of the plural when refering to 'curves' rather than the singular. I am perfectly aware that the R-D equal-loudness contours are not precisely the same as the earlier Fletcher-Munson. Both however, are close enough for the purpose of illustrating Mark's (and my) general point.
Old 11th March 2011, 11:48 PM   #105
AEIOU's Avatar
Some of us includes me.
You're welcome.
I frequently/often use a VIRGULE in my own posts/replies also/too.
Actually neither one of the two is correct. There is an even newer ISO standard, but I'm sure you already knew/know.
Anyway, I still don't understand why we are talking about crossovers in this thread. Maybe you could explain that one to me.
Old 11th March 2011, 11:51 PM   #106
Ian444 is offline Ian444  Australia
Not at all If you are going crazy then we're all going crazy together
Since I bought the CHR-70 and fitted them to the Lotus cabinets designed by Scottmoose above, I have never looked back. I would need to spend thousand/s on source before I needed better speakers. Thank you both (and others) for excellent contributions for DIYers. Mark I hope your Gen 3 drivers don't stray too far from the originals since the Gen 1/2 designs were right on the money.
Old 11th March 2011, 11:53 PM   #107
AEIOU's Avatar
Any pictures?
Old 12th March 2011, 05:30 AM   #108
Scottmoose's Avatar
None of them are 100%, but as noted, they are all are perfectly adequate for illustrating Mark's (and my) point regarding the avoidance of XOs in (or preferably within an octave either side of) the critical hearing BW. Which is the, er, point.
Presumably because some people wish to use these drive units in various forms of multi-way setups.
Old 12th March 2011, 06:08 AM   #109
wushuliu's Avatar
Mark will you be targeting similar SPL w/ the 8 ohm as the 4 or aiming higher?
Old 12th March 2011, 10:43 PM   #110
markaudio's Avatar
Hi Ian,
Thanks for your kind words.
No worries, the CHR Gen. 3's are more about "evolution" rather than "revolution". So the changes aren't radical. The things I hadn't anticipated was the interest for an 8 ohm coil. So we'll be busy in the next 10 days experimenting. I'll keep everybody informed.
Cheers
Mark.
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 06:02 PM
New CHR-70 markaudio Markaudio 68 3rd February 2011 02:44 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 02:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 12th January 2010 12:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
