| Markaudio Designers and builders of audiophile grade drivers |
Hi all. I have been thinking to build a pair of pencils with the alpair 10/12.
But seeing over the forum, a lot of people talk about the alpairs not being the most adecuated for rock/bass heavy music... i don't listen nothing too heavy, and also not so loud, but i don't want to be worry of break the drivers any time i listen to the allman brothers or if i should raise the volume control or not when i'm listening a nice upright bass solo...even i'm not sure if the bass would be nice enough at normal listening levels.Can someone give some advice about this? Max. volume levels, bass extension, etc? Would it be very appreciated Last edited by fxs; 27th February 2011 at 08:41 AM. |
#2 | |
Given what you've written, there's no problem with Alps playing rock/heavy music within sensible application. This applies to pretty much all full-range drivers. Indeed, when compared to high-efficiency full-rangers with short Xmas's, Alps are very bass capable. Historically, the challenge has come about from those DIYers with less experience who read a large X max in the specs and assume the driver can be driven hard. This assumption was not correct. As a general guide here's what you need to do: 1 - Size up your listening room and choose an Alp model to suite, e.g 4 metres X 6 metres could be Alp7's if you're not playing so loud or Alp10's and 12's if you want the system to handle more output. 2- Select a descent complimentary box design, e.g. Pencil series boxes work well in larger spaces while smaller vented boxes are usually more practical for lesser sized rooms. 2 - Match up your amp output. For example, class A/B up to X2 the rating of the driver, e.g Alp10 is rated at 35 watts so amp outputs of 70 watts is fine. You could go more but exercise caution with the volume control. Its simply a question of being practical. Once you've got the system set up, run the drivers in carefully and load them sensibly.Alps are capable of playing loud if the box design and set up is well sorted. Remember, you need your ear-drums for a lifetime. Never fails to amaze just how many DIYers are risking longterm damage to their hearing. Cheers Mark. |
#3 |
Thanks for your response Mark
- My room is about 5X5 meters, but not so much space for the pencils (with alpair 10/12). The pencils need to much space to breathe correctly? Of course, i can make space for the pencils - My amp is a harman receiver rated at 40w/channel. The harman receivers are supposed to be realistic about the power ratings (and so, are more loud than known receivers rated at 100 w eg). If you know something about this, i'm ok with that 40w/channel? - About your comment on the ear care , that means the alps 10/12 can play to ear harm levels without breaking? If so, that answers my question about the power output .- In another issue, i would like to ask you about the off-axis response of the alps on the pencils. It's supposed to be the radiattion pattern relatively constant up to some khz? I have read about how big and real it's the soundstage if the off-axis response is similar to the axis response (at least to some khz). Thanks! Last edited by fxs; 27th February 2011 at 10:25 AM. |
#4 | |
Id be tempted to look at Alp10 in Pencil 10.2's. 5X5m is a good size room so should be a nice match. Alp7 in Pencil 7 could also be a nice alternative if you need to look after free space in the room. The Harmon receiver for either Alp10.2 or Alp7 is OK, although "receivers" tend to be a compromise build. If you have the opportunity to upgrade, it would be worth considering a change. Yes, Alps (most any driver) can damage hearing given enough exposure to high volumes. Your axis question, the emittance output is directional hence on/off-axis responses are considered representative of this feature. Bear in mind that room influences will also likely affect the outcome. Thanks Mark. Last edited by markaudio; 27th February 2011 at 12:47 PM. Reason: typo fix |
#5 |
Thanks again for your answers Mark. I think i will be building the pencils 10.2
- Given what you said, then itīs possible to have about 80-90db at 3 meters aprox., playing heavy bass content, without risk of break the drivers? I probably wouldnīt listen to such high levels, but i want to have the capability to play loud ocasionally .- About the stuffing material...the idea is to glue it to the inside walls? because the material would tend to block the open port. And this stuffing, should be uniform, more concentrated in some area,etc? - There is a difference between the gold and grey 10.2 drivers? Thanks again!
#6 | ||
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
thanks for the answer. what i really wanted to say is, if you donīt glue the material to the walls, the material should tend to fall and then blocinkg the port. Or the idea is have the material tighty packed between the inside walls?
#8 |
frugal-phile(tm)
If you use the recommended polyfluff (dacron/wool/acostistuff/polester wool/pillow stuffing) even at less than the recommended quantity it should friction fit. If you are worried some sort of support doesn;t hurt (staves like Tony, uses, some netting, dowels across). In ours the holey braces acted as support. Glue won't do much as very little of the damping will be in contact with the glue, and if the glue gets into the fibre any significant distance will reduce its effectiveness.
If well fluffed, even if the wool falls to the bottom it will not block the port. (Note: the above does not work with real wool which will fall into a clump & fall if not supported) dave
#9 |
planet10, i read this post: Alpair 10 Gen. 2 introduction.
now a few weeks later, how are playing this alps10.2? are the 3d soundstage similar to the alpair 7's? how is the detail? really i don't have listen any of them, but i have seen the 7's compared to the quads. for me, it's very important to have a realistic 3d soundstage (like if speakers disappear), and of course nice detail. Thanks in advance |
#10 |
frugal-phile(tm)
The 3d soundstage is similar to the stock A7, there but a bit shallow. The A7eN does it quite a bit better, blowing out the wall behind the speakers with good material.
Most of my A10.2 are still on the break in bench and i haven't tarted any up yet (i'm juggling well over a 100 drivers at the moment) dave
| Alpair 12 vs Alpair 10.2 and a little Fostex 166 | germpod | Full Range | 4 | 28th January 2011 03:19 PM |
| Alpair 10 more forgiving than Alpair 7 & 12 | tripathdude | Full Range | 3 | 6th November 2010 06:14 AM |
| Alpair 10 vs Alpair 12 | buzzforb | Planet 10 hifi | 0 | 30th October 2010 06:56 PM |
| Alpair 10 Bass + Alpair 5 - Woodwill Japan | markaudio | Markaudio | 16 | 26th January 2010 11:48 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| Page generated in 0.13682 seconds (82.47% PHP - 17.53% MySQL) with 10 queries |
