| Markaudio Designers and builders of audiophile grade drivers |
I am planning to make a desktop speaker build from these. Since space is less, I was considering 6.7 ltrs sealed box or the smallest ported box possible at around 11.2 litres, tuned at 48hz. I tried to simulate these in winisd and saw that the excursion exceeds max limits at around 90hz. To bring the excursion below limits, the power needs to be brought down to around 10w. the ported box showed this even if I increased the volume to 200ltrs. Am I doing something wrong here. Do I need to put an hpf in this? It should not be the case that I play the first song slightly loud and it blows. How are people handling this issue in general. I am attaching the winisd driver file and image for this. |
#2 |
No, you're not doing anything wrong. But what else did you expect? We're talking a small, low - modest efficiency FR driver here, not a 15in woofer. It's always going to be moving a fair way to generate low bass and / or higher SPLs unless you horn load it. It won't blow unless you have no mechanical sympathy at all, but common sense is also required regarding practical limitations. If you need high SPLs & low bass, you either need a bigger driver, dedicated LF units in support, or horn loading.
#3 |
frugal-phile(tm)
The largest vented box i was happy with was 9 litre. 5-6.5 litre sealed.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | ||
I will be using a sub also, this is for desktop use. Dave, I remember you mentioning that you have jack hidley's plate amps. Do you know if the speaker level output from the plate amp is highpassed or does it send the full output to the speakers, the documentation on the site doesnt mention it. Thank you for all the help guys... |
#5 | ||
frugal-phile(tm)
That should work. 15mm + bracing will work better than 18mm... i always feel you get the best downward dynamic range if the driver is coupled to at least the back of the box. We have 2 braces in our (nominal) 5.5 litre BB miliSize boxes Quote:
dave
| Alpair 12 vs Alpair 10.2 and a little Fostex 166 | germpod | Full Range | 4 | 28th January 2011 03:19 PM |
| Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs | tripathdude | Full Range | 1 | 7th November 2010 05:04 AM |
| Alpair 10 more forgiving than Alpair 7 & 12 | tripathdude | Full Range | 3 | 6th November 2010 06:14 AM |
| Alpair 10 Bass + Alpair 5 - Woodwill Japan | markaudio | Markaudio | 16 | 26th January 2010 11:48 AM |
| WinISD - Cone Excursion | Mutley666 | Subwoofers | 12 | 12th December 2005 02:14 AM |
| Page generated in 0.09656 seconds (77.98% PHP - 22.02% MySQL) with 11 queries |
