Alpair 12 break-in question: 2mm? - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th April 2011, 10:47 AM   #41
Originally Posted by zman01 View Post
StevenZ,
Good choice Ottmar Liebert, Guitarisma, and Acoustic Alchemy are only list for phase 2 of breaking in the drivers.
For phase 1, I am thinking Chopin...
Zia
thanks guys, any recommended albums from these guys. I just want to go and purchase couple of albums each for phase 1 and 2 and play them without listening much
whats the recommended mode for burnin - on its own, OB, FAST, with a sub. Any difference it makes how you are doing the burn in.
Old 5th April 2011, 05:10 PM   #42
zman01 is offline zman01  Bangladesh
Acoustic Alchemy - I have 2 albums, both I like - The New Edge and Reference Point.
Guitarisma: The Charisma, Passion & Romance Of The Guitar (Various Artists)
Ottmar Liebert" Nouveau Flamenco
I am sure others can suggest some great stuff also
Beware - some of these tracks are pretty rhythmic, have some drums - would be careful using them for even phase 2 listening.
For phase 1 even gentler stuff...
Will have my drivers put in OB.
Old 15th June 2013, 08:33 PM   #43
rongon is offline rongon  United States
rongon's Avatar
Just as a check that I haven't done anything wrong with my Alpair 10.2's...
First several days, I played them at a very, very low volume 24/7, talk radio and classical music, from a receiver.
After a few days, I brought them out to my main system, with a 6-watt per channel tube amp. I played them at a higher level, but still very "moderate," only classical music and some acoustic jazz. One Villa-Lobos piece built to a bit of a crescendo, with a bass drum thwack. I quickly turned it down, even though it had been playing at a low level. Scared me. I hope that didn't do any harm...
Then they went back to the receiver, again playing 24/7 at a very low volume. Some jazz CD's playing for a couple of hours now and then.
It's been over a week now. I lost track of the hours.
Today I have them playing from the main system at a low volume.
Can I crank them up to normal (moderate, but would compete a little with calm conversation) listening level yet??
PS - they're in sealed cabs, Qcb about 0.66, maybe a little higher.
PPS -- Also, what would I listen for to know if I'd screwed the drivers up a little? Not catastrophic damage, but any fuzziness to the highs, maybe 'scratchy' sounding in the highs, other anomalies to listen for?
Old 16th June 2013, 08:51 AM   #44
markaudio's Avatar
Hi Rongon,
What's the internal volume of your sealed boxes?
Thx
Mark.
Old 16th June 2013, 11:35 AM   #45
rongon's Avatar
Hi Mark,
External dimensions are 210mm x 200mm x 370mm
Cabinet walls are approximately 15mm
So I subtract 30mm from each dimension to find internal volume.
180mm x 170mm x 340mm = 10.4 liters
Subtract 10% for displacement by driver, and it comes to about 9.5 liters.
Sound about right?
Old 16th June 2013, 12:09 PM   #46
rongon's Avatar
I saw something a bit scary. From post #17 of this thread:
6 hours at a time is OK providing the room temp stays below 24 degrees centigrade. Best to avoid elevated temperatures inside the coil chamber during the early run-in period.
Uh oh... I had them playing the radio at a whisper, but I left them playing non-stop that way for a few days. I really hope that didn't mess them up.
If they had overheated during that time, what would the damage sound like? A certain fuzziness to upper mids maybe? A possible extra upper mid "sizzle"? Or am I being neurotically obsessive? (Wouldn't be the first time...)
Old 16th June 2013, 12:29 PM   #47
markaudio's Avatar
Hi Rongon,
Its very unlikely you've done any damage with only 6 watts on tap and a sealed box volume of 9.5 litres. With over 100 hours on your drivers, you can afford to start applying normal listening volumes. That should be something in the low 80dB's at a typical listening distance of 2.5 metres. If you haven't got a SPL meter, check out your mobile phone, you may be able to download an application to covert it into an SPL meter.
Bear in mind that with only 9.5 litres sealed box vols, the low frequency response will be restricted and the resonant driver frequency will be likely pushed up be several Hz; Due to potential air compression acting on the rear of the driver's power-train. Please make sure there's at least 25-mm (thickness) of descent sound insulation on the internals of the box. Usually, to get the best from these drivers in sealed box applications, bigger volumes are desirable.
However, maybe you plan to assist the bass with a woof(s) in which case some filtering might be planned. Should you wish to receive specific help with your project, start a dedicated thread on the Markaudio section. Include pics and information on your set-up and listening room.
Mark.
Old 16th June 2013, 02:55 PM   #48
rongon's Avatar
I think I'm worrying way too much! I'm playing them at avg level of about 70dB, with the odd 80dB peak here and there. If you meant average SPL in the low 80's at 2.5 meters or so, then wow, I need to crank it up some!
I just saw another thread where A10.2 owners are saying that it takes a long, long time for these drivers to really break in and open up. They sound really good now, and I'll be one happy camper if they keep on improving.
Thanks for your help with this.
PS -- These sound fabulous for solo piano. The lack of a crossover does great things for the sound of recorded piano.
Old 16th June 2013, 04:48 PM   #49
Bob Brines's Avatar
Mark can comment on this, but if I understand the break-in restrictions correctly, you have to get at least some excursion or no break-in is occurring. A mm or so excursion is permissible for "low power" break-in. The thing is, 1mm of excursion on the A10's and A12's is going to give you 70-80dB at 2.5m. And that's my normal listening level! So, my break-in procedure is to turn them up to a comfortable level and let them rip.
Bob
Old 16th June 2013, 05:09 PM   #50
rongon's Avatar
I will most happily commence with that procedure...
Immediately!
Alpair 12, Alpair 6M wushuliu Swap Meet 5 11th February 2011 07:33 AM
Alpair 10.2 break-in box? mctavish Full Range 22 31st January 2011 05:28 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 03:19 PM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 06:14 AM
Alpair 10 vs Alpair 12 buzzforb Planet 10 hifi 0 30th October 2010 06:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
