| Markaudio Designers and builders of audiophile grade drivers |
I'm wondering if anyone has contemplated building the larger MJK OB - the one with twin 15A's and a Fostex FE167E? Now that the FE167E is out of production, I guess the FE166E would be the replacement ... or would it?
It seems to me that the 10.2 could work well in the design. Comment? Anyone with actual pictures? Thanks Doug (Brisbane, Australia)
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all." |
#2 |
I've been thinking on the alpair 10.2 in an ob.
But alas, it takes me months to get a driver into a box. Norman |
#3 |
I've also been thinking of Alpair 10 Gen II in an OB. Wondering if driver will work well with no backwave in this OB format. The 7's work excellent (in OB) but they have a QTS of 0.574 as opposed to a 10 Gen II QTS of 0.35. Any thoughts out there?
Ramon |
#4 |
Any fullrange should work fine as long as you're using helper woofers to fill in the bass and a little of the midrange.
| L CAO in OB W/ Eminence Woofer | Nelson Pass | Full Range | 118 | 7th May 2012 02:11 PM |
| All Eminence OB | Yunick | Multi-Way | 551 | 15th May 2011 08:28 AM |
| Eminence beta-12lta on OB? | grantnsw | Multi-Way | 0 | 8th January 2010 02:38 PM |
| Eminence Kappalite15LF for OB? | mayhem13 | Multi-Way | 8 | 28th January 2009 02:13 AM |
| Page generated in 0.06852 seconds (75.18% PHP - 24.82% MySQL) with 10 queries |
