Alpair 12...Solstice building questions! - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 2nd February 2011, 10:43 PM   #11
Urchinn is offline Urchinn  United States
Yes, panel bracing will be used...exactly as in the beta plans. The screen mesh idea sounds good! Thanks.
Old 2nd February 2011, 10:53 PM   #12
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
panel bracing
Fluffed polyfill mostly stays where you put it, friction fit. With the bracing we use we are never spanning that far.
People have historical had nails sticking out the internal walls, dowels, strings or a mesh (like Chris suggested). In the last 2 builds we have done that need volume fill (Pensil7 & our variation on the Twin #6 MTM) stayed in place with friction.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd February 2011, 11:09 PM   #13
chrisb is offline chrisb  Canada
dave
OTOH, they didn't have a taper that expanded in the direction in which the fill density is reduced, so while the material is certainly light and has a lot of friction, I guess there's always a chance it could slip if a pair of wider boxes are moved around a lot - particularly if MDF is used (please don't - use Chip board instead), or the internal surfaces are treated with a gloss finish.
now on sabbatical
Old 3rd February 2011, 04:39 AM   #14
I'm guessing I'll use some sort of mesh or netting held in place with thumbtacks or something like that...just to keep it in place. Yes, I do move speakers around quite often. I am continuously fascinated by the different sounds/tones/textures that different drivers deliver.
Old 3rd February 2011, 05:18 AM   #15
doorman is offline doorman  Canada
doorman's Avatar
I used some fiberglass screen (replacement window screening) stapled to the cabinet side walls in a pair of MLTL's
Good Luck with your project
Don
Old 1st March 2011, 03:24 AM   #16
skeeter99's Avatar
So how did these turn out????
Old 26th April 2011, 12:52 AM   #17
skeeter99's Avatar
Did these ever get finished? I went on Audiokarma and searched again and didn't find anything ...
Scott
Alpair 12 Woden Solstice skeeter99 Markaudio 12 4th July 2011 06:37 PM
Alpair 12, Alpair 6M wushuliu Swap Meet 5 11th February 2011 08:33 AM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 07:14 AM
Alpair 10 vs Alpair 12 buzzforb Planet 10 hifi 0 30th October 2010 07:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
