Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 4th February 2011, 04:12 PM   #21
Scottmoose's Avatar
The removable back is a design feature I put into the pencil cabinets to help people tailor the damping to their particular requirements.
Just for reference, I would recommended avoiding the use of foam in these cabinets.
Old 4th February 2011, 04:25 PM   #22
Musik007's Avatar
Yes, Alpair 6P is 3-inch paper cone full range driver.
http://www.markaudio.com/sites/all/f...0Gen.2-A_0.pdf
Originally Posted by skeeter99 View Post
Very nice! Its such a tiny little driver
Old 4th February 2011, 04:27 PM   #23
skeeter99's Avatar
I wondered about that. Just polyfill in them according to the spec then add/remove to taste correct?
Old 4th February 2011, 04:30 PM   #24
Musik007's Avatar
Old 4th February 2011, 04:33 PM   #25
skeeter99's Avatar
That is one STOUT little 3-incher!
Old 4th February 2011, 04:42 PM   #26
Musik007's Avatar
Yes, 6P and 6M are two precise small sized full range drivers and hard to find the same in this class in the market.
Old 4th February 2011, 05:18 PM   #27
Scottmoose's Avatar
Right.
Old 4th February 2011, 06:09 PM   #28
doorman is offline doorman  Canada
doorman's Avatar
Once stuffing has been tailored to the end-user preference, is there anything to gain by sealing , as in making air-tight, the cabs?
Don
Old 4th February 2011, 06:20 PM   #29
Scottmoose's Avatar
Around the removeable back you mean? Yes, it should have a good seal. A strip of rubber sealing tape or similar around the stringers should do the job nicely. Difference won't be vast, assuming the box is made with a tight tolerance, but it's worth doing.
Old 4th February 2011, 07:35 PM   #30
doorman's Avatar
Thank You.
D.
El70 in Pensil? type Full Range 12 11th September 2010 07:41 PM
why does my pics show as attachments? AudioGeek Forum Problems 8 6th July 2004 11:54 AM
Pics from T.H.E. Show in Las Vegas Timn8ter Multi-Way 7 13th January 2004 03:56 AM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 05:48 PM
pics from 2002 Stereophile show dorkus Everything Else 3 9th June 2002 08:19 AM
Copyright ©1999-2013 diyAudio
