#11 |
Dear Markaudio. From you first post, I understand you can control the thickness of the cone in the neck area? Is that true? I thougt the cone bas made, by pouring paper pult onto a net, and that way the cone will be equally thick all over the cone?
#12 |
Is there an MA driver the same as the CSS EL-70?
Another unrelated question: is there a dealer in the Philippines for MA speaker drivers? |
#13 |
- not really-(and a bone of contention for some
If the Alpair6P went 10-15Hz lower .........
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#14 |
frugal-phile(tm)
6p has the classic vintage sound nailed ... it is a bit soft on the top, the 6p would need to go at least 30 Hz lower to equal the EL70 LF response -- only the A10.2 goes lower.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#15 |
Thanks for the info. So reading in this forum i have read some comments by MA that there is a fear of abusing or over driving his fr drivers. I think it might be due to the fact they sound so good but give me more; volume, involvement? So maybe too much to expect from a single 4"but can a bigger,stronger driver be a solution 5-6" or 2 4" per side? Not heavy bass augmentation but more volume with the same finesse.
#16 |
The A10.2 seems to meet the needs of a lot of people. That might be worth investigating.
Sent from my tricorder. |
#17 | |
at the risk of censure - more volume and bass extension than 7.3 , yes - "finesse" in the upper mids/top, maybe not
#18 |
Personally I don't really understand why one should have x (insert number) of somewhat by a small margin different drivers?
For me it would makes more sense to do it the (Apple way). It should reduce costs as well. 1. One driver for fullrange for a big room 2. One driver for fullrange for a small room 3. One driver that would work as a midtweeter in a "Fast" system. And that's it. Put the energy, focus and therefor cost on three drivers instead of x numbers would make much more sense in my view. /Jacozz |
#19 | |
frugal-phile(tm)
dave
#20 |
What about my suggestion?
Make a sandwich of paper and alu? Best of two worlds? (At least in theory) /Jacozz |
| Thread Tools | Search this Thread |
| Markaudio CHR-70: Amplifier options? | mkbrooks | Chip Amps | 10 | 15th June 2011 02:46 PM |
| FS: pair of MarkAudio CHR-70 drivers | albireo13 | Swap Meet | 5 | 30th November 2010 08:07 PM |
| Alpair 6P Gen. 2 (paper) introduction | markaudio | Markaudio | 21 | 20th November 2010 02:10 AM |
| My first build! MarkAudio CHR-70 in da house | tresch | Full Range | 38 | 31st August 2009 10:07 PM |
| Page generated in 0.10068 seconds (78.83% PHP - 21.17% MySQL) with 11 queries |
