New Alpair 5? - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 3rd January 2011, 01:50 AM   #11
winslow is offline winslow  United States
And finally these guys are really popular world wide, but I don't know who makes them:
Products
In particular the Legatia 3 and 3 SE.
You can check out the MSRP as well.
So I think the market is there if you could tap into it. I wish I could be some marketing whiz and get you on the world car audio map and make you millions of dollars...but I'm just an enthusiast who roots for the under dog.
Old 3rd January 2011, 03:56 AM   #12
The cheerleading aside, you have to ask yourself is from a business point of view does it make sense to have a 3, 3.5, and a 4" speaker? There has to be a reason why the A5 was discontinued. Was there too much overlap? I don't know the answers to the business side of things. Maybe some of your dealers world wide could better answer this.
For my particular niche market the A5 was awfully attractive...but I am sort of late arriving to the wideband scene.
Too many choices can be a bad thing. Heck I've spent 5 days trying to decide on if I would like the gray or gold coned old A5 the best...and I still can't really make up my mind other than you paired the gold coned version up with the SDX7 on your webpage for a reason.
Old 3rd January 2011, 05:35 AM   #13
_henry_ is offline _henry_  Australia
i like the a5 signature as in very detailed, fast and also forgiving.
there is no harshness, and just the right air.
as for car application, i kept reminding a good friend of mine to use it for his project or competition to create the ultimate solution for the soundstage above the dash.
cheers
henry
Old 3rd January 2011, 06:36 AM   #14
markaudio's Avatar
Originally Posted by winslow View Post
The cheerleading aside, you have to ask yourself is from a business point of view does it make sense to have a 3, 3.5, and a 4" speaker? There has to be a reason why the A5 was discontinued. Was there too much overlap? For my particular niche market the A5 was awfully attractive...but I am sort of late arriving to the wideband scene.
Hi Winslow
I haven't discontinued the Alpair 5. I make drivers in batches so as stocks get low (mine and the dealers) we start a build program. The approach also affords me time to improve designs in-between builds. There's allot of choice in driver sizes up to 3" so its a tougher market place for the Alp5. Its sales are steady but slow compared to Alp6 and Alp7.
Many driver offerings can be confusing but it is best for project makers in the long run. It does mean there's a good chance of finding a nice driver to suit a particular project.
Cheers
Mark.
Old 3rd January 2011, 02:44 PM   #15
Thanks Mark. I must have misunderstood about the A5's production. Good to know how you do things.
Old 3rd January 2011, 02:45 PM   #16
Gold or silver cone?
cheers
henry
Old 14th January 2011, 02:34 PM   #17
MarkLai is offline MarkLai  Hong Kong
Hi Mark,
I'm planning for my home theatre speakers. I'm thinking A7 Pencil for the fronts.
What do you recommand for the Center as well as the Rear sides? A5 or your new 50mm?
I couldn't find much boxes design on A5.
My sitting room is, typically HK size, 2.4M between front and back walls.
Thanks,
Mark L
Old 14th January 2011, 04:49 PM   #18
chrisb is offline chrisb  Canada
Originally Posted by MarkLai View Post
Hi Mark,
Thanks,
Mark L
I'm playing right now with exactly such a configuration - A7 for L/R mains and center. I have a couple of pairs of enclosures with A7 at the moment, but only 1 is Pensil - so I'm temporarily using one of those laid on its side under the 47" screen.
As most modern surround receivers have a great deal of flexibility of XO freq / EQ settings for individual channels, you can probably get away with less than full bandwidth for the center, so much smaller enclosure design than Pensil would most likely be adequate - but I'd definitely recommend the same driver for all 3 main front row channels. It wasn't until I played around with the EQ/level settings that I understood how much information is present in the "true" center channel, and it's the last place I'd want to compromise bandwidth or excursion capability.
Depending on the final number of surround channels (mine can do 7.1 - a world of pain for which I'm not quite ready) smaller drivers such as the CHR70 or Alpair 5 would likely be sufficient for a room your size.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 10th March 2011, 02:30 PM   #19
Bill poster's Avatar
A 90mm version of the A5 would be great. I guess that the HF rise wd need to be tamed for in-car use plus an increase in power handling but the potential is there, the in-car market I'm guessing is much bigger.
Old 12th March 2011, 04:44 AM   #20
Chrisb, Bill,
Thanks for the information.
I've decided to buy the Denon AVR1161 recever 5.1 channel. (75W per channel stated)
The spec. does not state to drive 4ohm. (up to 6ohm spec)
For my room size, I prefer CHR70 at the moment for lower cost (the Gen. 3 is coming)
I've other amp/ speaker (most likely a A7 Pencil from Tony) for stereo music enjoyment.
The A/V is for my wife and the girles HT.
I'll gether more information before I kick off the project.
Alpair-10 with Alpair 5, German combo markaudio Full Range 17 7th November 2010 11:58 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 05:04 AM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 06:14 AM
Alpair 10 vs Alpair 12 buzzforb Planet 10 hifi 0 30th October 2010 06:56 PM
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 11:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
