Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 22nd December 2010, 12:27 PM   #1
Knight Rider's Avatar
Default Pensil series loudspeakers for small listening room
Hello!
I have planned to built some simple fullrange loudspeakers during next months. I noticed that Pensil series louspeakers are quite easy to build and offer pretty good sound. But I have a problem; I don't know which model should I choose. Could you please give me any tips/recommendations which Pensil-series loudpeakers should I choose for small listening room (L=4.2m x W=3.3m x H=2.4m)?
I would use finnish plywood (birch) for construction material (density 680 kg/m3). Available thicknesses 15, 18, 21, 24 mm. Which one is best?
Old 22nd December 2010, 03:47 PM   #2
Scottmoose's Avatar
Depends on what you listen to & what you value sonically. If you like small ensembles, folk etc. & don't listen particularly loudly, one of the 4in models should do you fine. If you need greater SPLs / more dynamic range, then whichever happens to be the largest model that fits through your door.
Old 22nd December 2010, 06:49 PM   #3
Maybe I should go for the Alpair 10 or even 12 then, because I listen also hard/heavy rock music. I prefer a little bit warm sound without any listening fatigue. I have successfully used open baffles with the combination of eminence alpha 15A + tangband w8-1808 drivers. They are based on MJK's worksheets and I like their sound a lot.
It reads on the box plans that 18-20 mm ply is recommended. I guess it's ok if I use birch ply of thickness tolerance 20.0 -20.9 mm? It's the closest match.
Br
Arto
Old 22nd December 2010, 08:23 PM   #4
Scottmoose's Avatar
The material will be OK.
Assuming it's well recorded, you'll need all the dynamic BW you can get for that sort of material, so the A12 will be the least compromised in that regard.
Old 27th December 2010, 07:23 PM   #5
Thank you so far Scott!
Two more questions:
1) How much space is needed between Pensil 12 and side/front walls?
2) Can I listen in "near field" (~2-2.5 m distance between loudspeaker and listener)?
Br
Arto
Old 27th December 2010, 08:46 PM   #6
markaudio's Avatar
Two more questions:
Br
Arto
Hi Arto,
Re your questions, we have small apartments here in Hong Kong. Several pairs of 12's are in corner spaces within 7 to 10 CM in corners of rooms. They play well. Likewise on listening distance, 2 to 2.5 M works fine.
Most of the guys here operate Alp12's in these smaller environments with lower power tube amps. In my case, one of Tony Wong's 8 watt 300B SET amps does a nice job. You like a "warmer" sound so I'd suggest a tube amp for your set up. Older MOFSETS and possibly some of the new class D's may also work but you won't need allot of power in a small room situation.
Also, check out your source component (CD player etc). Since you're closer to the drivers, they will reveal detail. You'll need a good component and descent quality music recordings. Not so critical for your rock music as outputs will be higher, but classical, female vocals, softer jazz etc will be will do well on Alp12's if the recordings are audiophile grade.
Scott may have more specific advice and information.
Cheers
Mark.
Old 28th December 2010, 11:40 AM   #7
Thank you guys!
Can you also give me an estimation what is the -6db point for bass extension (both pensil/superpensil 12)?
Old 29th December 2010, 01:27 AM   #8
markaudio's Avatar
Thank you guys!
From my memory its 46Hz for Pencil and 40Hz for Super-Pencil (these figs might be -3dB). Scott will know, think he's still on the Christmas hols.
Cheers
Mark.
Old 29th December 2010, 09:00 AM   #9
Scottmoose's Avatar
About that; in practice of course the room dominates what you will actually get.
Old 29th December 2010, 05:51 PM   #10
Hello!
Have you guys compared what is the difference (bass quality/amount) between double bass reflex studio monitors and pensils?
Br
Arto
Pensil Series for Mark Audio Drivers planet10 Markaudio 46 28th September 2011 07:19 PM
Soundproof Listening Room Patrick Bateman Subwoofers 21 30th April 2011 11:35 PM
Nasty Room Resonances in New Listening Room TubeHead Johnny Multi-Way 4 23rd May 2009 11:13 PM
Piano in listening room? mikewu99 Multi-Way 3 2nd February 2003 11:29 PM
Listening room ding Everything Else 4 18th October 2001 01:20 AM
Page generated in 4.28533 seconds (3.37% PHP - 96.63% MySQL) with 11 queries
