Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 14th December 2010, 11:06 PM   #1
frugal-phile(tm)
planet10's Avatar
Default Dec 14, A10.2, A6p, A6m have hit Madisound
The Mark Audio shipment has arrived earlier today at Madisound.
A6 metal is, i understand, in short supply. If that's what you've been waiting for grab em now.
A10 should be available with loose bezel cover, make sure to specify
Some A12s with loose cover too.
I'm already 1st in line.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th December 2010, 11:15 PM   #2
thanx dave , still not showing on their www . guessing you got the inside info .
Old 15th December 2010, 12:20 AM   #3
markaudio's Avatar
Yes chaps,
Alp6M - I should have made more. Also Alp6P. I still have some stock of parts so will try to make more drivers in Jan.
North America - talk to Madisound (Brian or Adam)
Europe - Talk to Blue Planet Acoustics (Nick or Thorsten)
At HK airport, 10 mins to boarding, must go>>>>>>>>>>
Happy Christmas
Mark.
Old 15th December 2010, 12:25 AM   #4
dave , what is the reason that you prefer the loose bezel cover ? just curious . heard you mention it before .
Old 15th December 2010, 02:29 AM   #5
frugal-phile(tm)
planet10's Avatar
I'd rather not use it. Althou it stiffens & damps the bezel a bit, its primary purpose is cosmetic. It makes the driver wider & requires a deeper rebate (so a tight baffle becomes even tighter, and doesn't leave a whole lot of meat on an 18mm baffle to suppirt the driver. The biggest thing thou is that it creates a ring that bumps up 1-2mm . No bezel cover gives you almost flat from the surround to the baffle.
dave
Old 18th December 2010, 12:37 AM   #6
frugal-phile(tm)
planet10's Avatar
Got my order in today.
dave
Old 18th December 2010, 02:39 AM   #7
mp9 is offline mp9
nice!
Old 18th December 2010, 06:03 AM   #8
markaudio's Avatar
Hi Woody.
Dave's mostly correct although the primary reason for the bezel is to increase damping and stiffening so where possible, please use the bezel.
For all Alpairs, its vital to minimize the side wall depth and round off the rear of the opening. Alpair's generate a large back wave from the rear of the cone. It's vital to keep baffle side-wall profiles to a minimum. So recessing a new Alpair 10 into an 18-mm baffle should leave you with a (from my memory) 7-mm side-wall that is best rounded off (inside edge of baffle) with the bezel attached.
Must dash, I'm now having a few day's off before returning to HK.
Cheers
Mark.
Old 18th December 2010, 07:11 AM   #9
I cant see them on the Madisound website either. Has anyone except Dave ordered them yet? Dave, did all the new models show up on the markaudio page at madisound? i can only see the older models (Alpair 7 and 12, CHR-70)
looking forward to a pair soon
cheers,
mymindinside
Old 18th December 2010, 07:00 PM   #10
frugal-phile(tm)
planet10's Avatar
I've had mine on order since before they shipped from Hong Kong.
dave
Stuart, Fl Dec. 5, 2010 signguymick Clubs & Events 0 14th November 2010 11:46 PM
Mitsubishi DA-A10 gtilles Solid State 3 23rd April 2010 01:50 AM
Dynaco A10 XO wising Multi-Way 0 24th March 2009 03:16 PM
Duson A10 - help needed diabolis Solid State 4 28th March 2008 07:40 AM
Oracle Delphi( Best arm for this dec) croft Analogue Source 32 29th June 2004 05:04 AM
Page generated in 0.09273 seconds (80.54% PHP - 19.46% MySQL) with 11 queries
