Dec 14, A10.2, A6p, A6m have hit Madisound - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 16th January 2011, 05:05 AM   #21
markaudio's Avatar
Originally Posted by Patrick Bateman View Post
Dope the cones. I do that with the MCM 55-2421s that I'm in the habit of using.
Please DON'T "dope" CHP-70 cones (or Alpair 6P). These ultra-low mass cones only remain stable because of a binding agent embedded with the fibre. If an additional coating is added and there's an adverse reaction, kiss the drivers "good by", into the bin and forget about any warranty.
I've not designed these paper cones to take an additional coating in the form suggested. Both drivers rely on their power-train's retaining low mass since they are tolerance critical. CHP-70 and Alpair 6P drivers aren't big heffalump woofers where adding mass is less likely to affect performance.
The CHP-70's cone will resist temperature and humidity but the better choice for a car environment is the CHR-70. Its alloy cone won't be affected by typical conditions inside cars.
Mark.
Old 16th January 2011, 10:34 PM   #22
markaudio's Avatar
Hi Guys,
I've 3 emails asking me about coating cones. I've not done any experiments using additional coatings on any Markaudio drivers. Dave (Planet 10) sent me pair of early Enabled CHR-70. I tested these against a non-treated CHR's and there was almost no difference between these drivers on the major parameters. Only a slight lowering of SPL. The Enabled drivers became part of a listening event here in HK. I'll try to find the time to look for the posts on this event.
Its worth talking to Dave on treating cones. His knowledge and experience is extensive.
In the meantime, as per my previous post, please don't paint dope over the CHP and Alp6P paper cones.
Mark.
Old 17th January 2011, 12:44 AM   #23
frugal-phile(tm)
planet10's Avatar
I am very cautious with anything on the MA cones. The metal cones get a small amount of gloss after being spotted -- less than any of the Fostex for instance.
My only paper cone MA experience is with the EL70, and it responds very well to my treatment. Amount of coating is again kept small.
I will be tackling the A6P soon. I will be using even less material on them, and will be proceeding carefully, the 1st couple pair of drivers being considered expendable. I am in the process of getting 2 pair of boxes so that treated vrs untreated can be directly compared.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th January 2011, 01:07 AM   #24
markaudio's Avatar
Dave and me have talked about making a "special" treated driver (Planet 10 exclusive). Maybe there's time this year to make some progress on the idea.
Cheers Mark.
Old 17th January 2011, 02:48 AM   #25
frugal-phile(tm)
planet10's Avatar
There is a whole series of drivers in my head. Some work would need to be done to get them ready. And funding before that.
dave
Old 17th January 2011, 03:18 PM   #26
winslow is offline winslow  United States
What about a spray of Scotchgard?
Old 17th January 2011, 06:21 PM   #27
markaudio's Avatar
Hi Winslow,
Aside the risk of adverse reaction to the solvents involved and the added mass issue, its going to be near impossible to cover both sides of the cone with 100% certainty. Any small gap will expose the cone to its environment, defeating your objective.
Stick with your original idea of putting the CHP's behind a grille. Compared to allot of decent car drivers, they're moderately priced so its not the end of the world should you need to replace them every 3 years or so. If you live in a region where the weather's not too wide ranging or very humid and the car's interior is reasonable ventilated, chances are the drivers will have a normal service life.
I'm on record encouraging experimentation on several threads but this time trust me when I tell you "don't dope, spray, Scotchgard etc" (unless you're prepared to experiment and bin drivers).
Mark.
Old 17th January 2011, 07:55 PM   #28
Point taken.
I am hard headed and really want to try the paper out, but it might be too much squeezing a square peg through a round hole type of deal.
That and the A6.2s are the same price as the old A5s, and I have a feeling the new A6s are better than the A5s.
I might should just shoot you an email to keep the clutter down on the forum.
Old 17th January 2011, 11:17 PM   #29
markaudio's Avatar
Point taken.
Hi Winslow,
We've water/humidity tested CHP/A6P cones. They are resistant (not impervious) so its not all bad news. But the safe bet for cars is CHR's and Alp6M's (or bigger Alps if there's room).
The new Alp6's are Gen 2 drivers while the Alp5's are Gen 1. I hope to be making Alp5 Gen 2's sometime this year but its dependent on a supportive bank manager (are there any?).
Please feel free to continue the chat on this section. How about starting a new thread (happy if you'd like to do this). I'd like to do more car audio this year so our sister company has just bought an old Hyundai Terracan. Its 10 years old with a "typical" sound system of that time. So I'll be taking the door cards off to start experimenting during the Chinese New Year holiday.
Cheers
Mark.
Old 18th January 2011, 01:36 AM   #30
I think you would be surprised at how many people "untreated" drivers like ScanSpeak Revelators in their cars with no problems. I ran Audax PR170M0 midranges for a while that were untreated paper and foam surrounds without issues. Plus us car guys are a funny bunch...we'll change stuff every so often to keep the install fresh.
Mitsubishi DA-A10 gtilles Solid State 4 10th July 2012 03:17 PM
Stuart, Fl Dec. 5, 2010 signguymick Clubs & Events 0 14th November 2010 11:46 PM
Dynaco A10 XO wising Multi-Way 0 24th March 2009 03:16 PM
Duson A10 - help needed diabolis Solid State 4 28th March 2008 07:40 AM
Oracle Delphi( Best arm for this dec) croft Analogue Source 32 29th June 2004 05:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
