Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 16th November 2010, 10:26 PM   #1
Default Small sealed box
Hello,
I'd like to make a small sealed box using a Markaudio driver. Which driver should I use?
Old 17th November 2010, 02:37 PM   #2
markaudio's Avatar
Originally Posted by Mooch View Post
Hello,
Hi Mooch,
We can try to help but you'll have to be more precise. Your existing question is similar to the "how long is a piece of string" scenario. Give me and rest of the guys some clues...............
1 - Your application (nearfield, desktop of full room) and room size?
2 - Your amplification and source components?
3 - Why you're considering sealed?
4 - Your musical tastes?
Mark
Old 17th November 2010, 04:37 PM   #3
frugal-phile(tm)
planet10's Avatar
And how small is small?
CHR is best suited (5.5-7 litre)
A10.2 should also work sealed, won't go as low and at 9-26 litre probably would not be considered small.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th November 2010, 09:42 PM   #4
EUVL is offline EUVL  Europe
A6.2 Bass reflex 3 litres.
Patrick
Old 17th November 2010, 11:13 PM   #5
Thank you all,
I'll try to answer Mark's questions:
1-10ftx15ft room not played loudly
2-in flux, right now playstation 1 and Advent Model 400 (I know it's pitiful but I hope to upgrade)
3-We need a speaker that is as small as possible
4-Folk, classical (but not big complicated symphonic things) and new music (such as Steven Mackey)
Dave,
You're right, in our situation 9-26 litre would not be small.
Patrick,
I'm glad you mentioned the A6.2. It's so new I didn't know if anyone had tried one in a sealed box. I assume you are referring to the metal version.
Thanks again, Chris
Old 18th November 2010, 01:21 AM   #6
frugal-phile(tm)
planet10's Avatar
The Advent 400 is a classic. In good condition probably worth more now than when they sold new in the late 70s.
I have a 2 litre enclosure (uMar-Ken6) that, in theory, works with either the A6P or A6M unchanged.
It might be possible to put the A6M in an even smaller enclosure -- using the initial prototype numbers i squeezed one into 1.5 litre.
dave
Old 18th November 2010, 01:34 AM   #7
frugal-phile(tm)
planet10's Avatar
Both Patrick and i are referring to a vented enclosure for A6M. Attached are sealed sims. If you have no need of real bass, you could probably live with a litre box.
dave
Old 18th November 2010, 01:53 PM   #8
Thanks, Dave. I knew your enclosure was vented but I didn't see "Bass reflex" in Patrick's response!
Old 18th November 2010, 07:00 PM   #9
wushuliu's Avatar
Let's say I want to use active dual subs up to 180hz. What would be the best sealed size for the A6 to meet that XO point?
Old 18th November 2010, 07:09 PM   #10
Small sealed box
"A6.2 Bass reflex 3 litres."
P.
ACI SV12 in small aperiodic or sealed box? Godzilla Subwoofers 13 8th May 2008 08:24 PM
servo sub for small sealed box? autopi Subwoofers 3 12th April 2008 03:49 PM
Which driver for a small sealed box. ShockValue Subwoofers 21 16th June 2005 04:25 PM
Small sealed box with linkwitz transform fb Subwoofers 7 8th April 2005 06:29 PM
how small of a sealed box could i get away with ? zuki Multi-Way 6 25th August 2004 08:12 AM
Page generated in 0.10656 seconds (77.76% PHP - 22.24% MySQL) with 11 queries
