Alpair 6M Gen. 2 (metal) introduction - Page 6 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 23rd January 2011, 04:57 AM   #51
norman bates's Avatar
Sounds reasonable but I have no idea.
Norman
Old 28th January 2011, 09:37 AM   #52
Bill poster's Avatar
the frame surround diameter is too wide for my application- only half joking when i ask if its possible to hack saw the outside edge off...
Old 28th January 2011, 08:18 PM   #53
frugal-phile(tm)
planet10's Avatar
A thot i have had too... not really practical without doing some remedial work to the basket afterwards.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2011, 10:24 PM   #54
wushuliu's Avatar
If actively crossing over at 300hz or higher, does the efficiency increase and if so by how much?
Old 28th January 2011, 10:55 PM   #55
Scottmoose's Avatar
No. The only way you can increase the efficiency of a driver is to horn load it (front horn. A back-horn, like all other vented boxes, only functions over a relatively narrow BW). However, by high-passing it, you will get more dynamic headroom & reduced distortion from the overall speaker system as the small A6 is not being asked to handle the LF, where power / excursion demands are highest.
Old 10th March 2011, 09:22 PM   #56
vitorio is offline vitorio  Spain
Hello all,
It's my first post in this great forum.
I'm planning a FAST system with Alpair 6M Gen2. The problem is SDX7 is out of stock. Any idea about wich other 6-8"
woofer can work?. What about MA woofer 6?. Speakers will play rock and movies (no classical music).
The croosover is active with Minidsp.
Thank you, and please excuse my bad english.
Old 11th March 2011, 02:24 AM   #57
frugal-phile(tm)
planet10's Avatar
Almost any good midwoofer will do.
I used SDX7 with the FF85KeN in th Tysen. I used a pair of MA $6 (CSS EL166) midbass in the next one.
The Alpair6.2s will adily fill the role the Fostex does in these. My next FAST will use a pair of Alpair5 (cabs done)
Mark's proto 6.5" Woofer, 1" silk Tweet combo (and the following posts)
dave
Old 23rd March 2011, 06:56 PM   #58
type is offline type  United States
Will the Alpair 6M produce more bass than the Alpair 7?
Old 23rd March 2011, 08:55 PM   #59
frugal-phile(tm)
planet10's Avatar
No, i don't think so. It will thou likely be the 3" leader in bass production.
dave
Old 26th March 2011, 05:11 AM   #60
dave
I like small drivers. How close would it be? As a point of reference, would the 6 have more bass output than let's say the Fe103e?
Alpair 6P Gen. 2 (paper) introduction markaudio Markaudio 30 21st August 2013 04:59 AM
Alpair 6 - Gen 2. - Prototype 1 markaudio Markaudio 53 11th November 2010 05:18 AM
Alpair 12 - Gen 2 otto88 Markaudio 2 30th September 2010 05:06 PM
alpair 6 + 10 gen 2, availiable Monday norman bates Full Range 2 18th September 2010 10:46 AM
When is the alpair 10 gen 2 coming out ? norman bates Markaudio 10 1st March 2010 11:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
